bmw calipers backwards?, nipples on bottom and won't pump up |
my15window |
Sep 10 2003, 05:50 PM
Member Group: Members Posts: 61 Joined: 23-March 03 From: fort collins Co. Member No.: 465 |
so did I screw up I've bleed these to death and read the archieves and bleed them again. no air at all or pedal pressure, did it the one man method .. if it shoots fluid the calipers arn't stuck are they?
Brad Roberts |
Sep 10 2003, 05:52 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Help me out. How are they mounted ?? Flip them from side to side if you have the bleed nipples on the bottom. Air bubbles rise.. you'll NEVER get the air out with the bleed nipples facing down.
B |
tat2dphreak |
Sep 10 2003, 06:39 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Sep 10 2003, 06:52 PM) you'll NEVER get the air out with the bleed nipples facing down. you said it!!! |
ChrisFoley |
Sep 10 2003, 07:15 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
QUOTE(Brad Roberts @ Sep 10 2003, 07:52 PM) you'll NEVER get the air out with the bleed nipples facing down. No, but you will certainly go through a lot of brake fluid trying. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:00 PM |
