> Reverse Backup Switch, Reverse Backup Switch
Above82
post Mar 19 2006, 06:53 AM
Is there a way to remove the wire harness from the engine tin where the reverse backup switch goes through? I removed the backup switch from the transmission but the casing for it is too big to fit through the hole. Does it come apart????
Thanks!
Replies(1 - 1)
ejm
post Mar 19 2006, 07:00 AM
I can see the light at the end of the tunnel
The wiring for the switch has "bullet" type connectors, slide back the boot if there is one and carefully pull the wires from the switch.
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png)
- Lo-Fi Version Time is now: 16th June 2024 - 10:01 PM
