Is there a way to remove the wire harness from the engine tin where the reverse backup switch goes through? I removed the backup switch from the transmission but the casing for it is too big to fit through the hole. Does it come apart????
Thanks!
ejm
Mar 19 2006, 07:00 AM
The wiring for the switch has "bullet" type connectors, slide back the boot if there is one and carefully pull the wires from the switch.
