Reverse Backup Switch, Reverse Backup Switch |
Above82 |
Mar 19 2006, 06:53 AM
Newbie Group: Members Posts: 2 Joined: 21-July 05 From: Palm Bay FL Member No.: 4,445 |
Is there a way to remove the wire harness from the engine tin where the reverse backup switch goes through? I removed the backup switch from the transmission but the casing for it is too big to fit through the hole. Does it come apart????
Thanks! |
ejm |
Mar 19 2006, 07:00 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The wiring for the switch has "bullet" type connectors, slide back the boot if there is one and carefully pull the wires from the switch.
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png) |
Lo-Fi Version | Time is now: 5th May 2024 - 06:50 AM |
