911 headers on 914-6, turned around |
thesey914 |
Mar 19 2006, 07:37 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Has anyone run this type swapped 180 with an extension pipe, or will they foul the firewall?
Friend of mine has changed to SS and has these spare (not my photo) Attached image(s) |
ArtechnikA |
Mar 19 2006, 08:07 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i seem to recall an issue with the flanges being wrong if they're flipped. they can be cut and rewelded but that cuts into the percieved cost savings. i can't say for sure other than if it were easy, everyone would be doing it. so check the flange issue and pls correct me if i'm wrong.
i think you oughtta leave 'em alone and run external sidepipes :-) ... |
IronHillRestorations |
Mar 19 2006, 08:11 AM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I believe they are too wide, and won't fit.
ClayPerrine |
Mar 19 2006, 09:15 AM
Life's been good to me so far..... Group: Admin Posts: 15,527 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You already have to trim the turbo lower valve covers to clear the control arm mounting ear. Those are going to run into the control arm mounting ear.
dimitri |
Mar 20 2006, 02:55 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
If you mount them with collector pipe on the inside, facing center of
engine, it should work. Mounted on the outside, collector pipe will interfere with rear suspension. Dimitri |
Kerrys914 |
Mar 20 2006, 03:48 PM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Maybe I better look at mine (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I have turbo covers (it's faster now) and don't reall doing this? Is this 100% or most of the time deal?? Cheers |
ClayPerrine |
Mar 20 2006, 06:51 PM
You can install them without trimming them, provided the engine is out of the car. If you put them in without trimming them, you will be pulling the engine for the first valve adjustment. There is no room to get them off without trimming the ribs on the back. |
Joe Bob |
Mar 20 2006, 07:07 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
You will also need an extension(s)....remember all 911s have short pipes...like the drivers... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Sparky |
Mar 20 2006, 07:20 PM
Mahna Mahna! Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 |
Even if you cut the flanges and flip 180 wont the collecters then be right under the push rod tubes? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Cap'n Krusty |
Mar 20 2006, 07:22 PM
And then there's the question of what kind of pushrods to use in those tubes .................... The Cap'n
Eric_Shea |
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
How's that little white and red thingy of yours running these days? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) That's a cab right? (talk about an estrogen induced stubby-mobile...) You letting the Mrs. drive it now? (IMG:http://www.914world.com/bbs2/html/emoticons/lol3.gif) |
SirAndy |
Mar 20 2006, 07:23 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
push rod tubes ??? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Kerrys914 |
Thanks Clay (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Haven't done a valve adjustment yet with the engine IN (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Sparky |
Mar 20 2006, 08:20 PM
Doooh man I picked the wrong day to give up coffee... Oil return tubes, push rod tubes, them there tubey things between the head and the case (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) . |
Lo-Fi Version | Time is now: 12th June 2024 - 03:39 PM |
