distributor diagnosis, how do i get it timed will not run |
tom444 |
Mar 25 2006, 06:03 PM
Newbie Group: Members Posts: 27 Joined: 16-November 05 From: phoenix az Member No.: 5,140 |
I removed the dist and put it back now all I get spudder and a few pops but no start how do get running so I re set the timing ?
Dr. Roger |
Mar 25 2006, 06:04 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
points or optical trigger?
Dr. Roger |
Mar 25 2006, 06:06 PM
if your sure the ignition is being triggered correctly by correct points gap or optical trigger, then make sure your plug wires aren't switched.
then, if your getting sputtering out the tail pipes, then just advance your dizzy a bit and try again. |
Dave_Darling |
Mar 25 2006, 07:28 PM
You want to start out by setting the "static timing". Set the engine up to TDC on the #1 cylinder (use the flywheel or fan markings), then hook up an extra spark plug to the #1 plug wire. Tape it so the threads are touching a ground like the fan shroud. Turn the key to "on", and twist the distributor until you see a spark. Turn the key off, tighten the distributor clamp when the distributor is right where the spark gets triggered.
That should get you close enough to start the engine. Oh, and as was said--make sure your plug wires are on correctly!! --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 06:39 PM |
