Electical prob, Headlight low beam |
richardmosselman |
Mar 26 2006, 05:08 PM
slvr bullet Group: Members Posts: 390 Joined: 18-September 05 From: Victoria BC Member No.: 4,822 |
Hi people-my '72 914 driver's side headlamp low beam doesn't work. Have replaced the headlamp-still no worky. I'm hoping that it isn't the dreaded headlamp switch on the dash (mucho dinero,I hear). The switch does act up -sometimes you have to jiggle it. Any suggestions? I'd like to be able to drive @ night. BTW the fogs, the other headlight and the hi-beams all work. Thanks!
richardmosselman |
Mar 26 2006, 05:11 PM
OOps! Electrical prob (I'm not ticklish!)
racerx7 |
Mar 26 2006, 05:13 PM
Member Group: Members Posts: 119 Joined: 28-January 06 From: Belmont, CA 94002 Member No.: 5,489 |
Post a wiring a diagram and I will look at it for you. |
TINCAN914 |
Mar 26 2006, 05:14 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I might be talkin out of my ass, but have you recenly rewired the signals, marker lights, or brake lights? I ask because my marker lights are shaved, and the rear wires were mixed, and I only had one headlight working, screwed around with the wiring and believe it''s figured out, both lights work... From what others have posted, if things are not wired correctly, that will happen.
Good luck |
richardmosselman |
Mar 26 2006, 05:16 PM
Nope, haven't touched anything-just stopped working out of the blue.
markb |
Mar 26 2006, 05:30 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
This may be asking the obvious, but have you checked the fuses? Each high & low beam have individual fuses. After that, check the relay.
richardmosselman |
Mar 26 2006, 05:43 PM
Thanks,I'll chek the fuses-I didn't know about the separate hi/low fuses. I'm relatively new to the joys of teener ownership. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 29th May 2024 - 01:50 AM |
