| arc914 |
Mar 28 2006, 10:28 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 9-April 05 From: Sault Ste Marie,on,Canada Member No.: 3,905 |
hi all
what is the best way to clean my tranny so that i can re-paint it?all ideas entertained. my tranny is covered in road glue and pitted alot. arc914 |
| Twystd1 |
Mar 28 2006, 10:52 PM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Use the search function...
There are several (many) threads on the subject..!!!! Unless of course you are talking about the other TRANNY'S. (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Then MattR wil have to step forward and explain that to all of us.... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Twystd1 |
| Eric_Shea |
Mar 28 2006, 10:55 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Do not use the commercial engine degreasers. They "will" pit the mag. case. Basically a lot of elbow grease. If you'r looking for the 'new' look then 'walnut' media is the best.
| Dr Evil |
Mar 28 2006, 11:22 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I like easy off oven cleaner
| dlo914 |
Mar 29 2006, 01:55 AM
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
or pressure wash. that's what i did. got it done for free at school. the wash was hot water w/ some light detergent. cleaned the transmission up pretty well.
| URY914 |
Mar 29 2006, 06:26 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,310 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
| Joe Ricard |
Mar 29 2006, 07:35 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Why do you want to paint it? Walnut mdia blast wil make it nice and spiffy looking. then all you need to do it keep it leak free and clean.
| Pat Garvey |
Mar 29 2006, 09:28 AM
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I would warn against painting it...... Everything that hits it (stone, gravel, stc) will chip the paint & you'll eventually wind up stripping it all again because it will look diseased (don't ask how I know). have it blasted (walnuts) & let it be its natural color. Too many nooks & crannies to get paint to adhere to anyway. |
| Tobra |
Mar 29 2006, 09:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
I have used simple green and a scotch pad, worked on the bumper, and I was laying there anyway...topped it up about 50 ml after I cleaned it and took it out for a stellar 70 degree day. Needed to burn some gas out of it as I am changing the lines under the tank this weekend. If you take a hand towel, wrap it around your wrist and secure it with a rubber band, the simple green does not run down your arm, which I found annoying
| MrKona |
Mar 29 2006, 10:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Get it blasted. Here's my case after plastic bead blasting. I couldn't believe the difference.
| URY914 |
Mar 29 2006, 10:26 AM
You need to grind that VW logo off. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
| tat2dphreak |
Mar 29 2006, 10:37 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
brake cleaner and simple green cleaned mine...
gunk foamy engine cleaner wasn't strong enough... |
| arc914 |
Mar 29 2006, 11:14 AM
Thanks for the input.That pic of your tranny is exactly what i am looking to do.I thought that i would have to paint to get that effect.
I will not paint only clean then blast. arc914 |
| Grimstead |
Mar 29 2006, 11:52 AM
Cheaky Monkey ![]() ![]() ![]() Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
So Okay. If one was to go the media blasting route, would there be any benefit of doing a clear coat afterwards to make it easier to keep clean down the road?
Also, is there any special prepping that needs to be done to protect the innards? |
| bd1308 |
Mar 29 2006, 12:02 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
whatever you do, DONT touch the tranny with your bare hands. Metal splinters hurt.
b |
| Mueller |
Mar 29 2006, 12:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
(IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) what?? ...you've been touching the "wrong" kind of tranny (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) adding a clear might work, issues would be yellowing and it could still chip due rocks and such....once the clear is chipped away, the surface will be exposed to the elements and start to tarnish |
| Grimstead |
Mar 29 2006, 12:13 PM
How long do you think the media blasting finish would last before it would start to tarnish again without a clear coat? I ask cause I really like that clean look but if the "Bang for the Buck" isn't there (ie, starts to tarnish after a month or so) not sure if it would be worth the hassle.
| Mueller |
Mar 29 2006, 12:24 PM
i heard the "secret" is to apply a liberal amount of WD-40 to the case right after media blasting..... |
| Cap'n Krusty |
Mar 29 2006, 12:25 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
DO NOT under ANY circumstances use sand blasting or glass bead blasting. Just don't. You HAVE been cautioned! The Cap'n
| Brian Mifsud |
Mar 29 2006, 12:41 PM
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
My transmissions have always been gunked up with ENGINE oil, never gear oil.... Now the TRICK is how to keep that VW from ever leaking oil..... |
Lo-Fi Version | Time is now: 15th April 2026 - 06:02 PM |
