| kenpolives |
Mar 29 2006, 01:25 PM
Member ![]() ![]() Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
Just when I think everything is going great, my wipers decide to turn on by themselves when I finish making a right hand turn. They wipe once or twice and stop. The lever is in the off stop, and I am not hitting the lever by accident. The car is a 74.
Anyone have this problem? I suspect the answer is time for a new switch but...... Anyone gotta a cheap working switch? |
| Joe Ricard |
Mar 29 2006, 01:51 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Cheap ? probably. Working? I don't know.
I Suspect you have a wire that has worn through and grounding it's self inside the column. or one of the screws has worked loose that holds all that crap together. |
| Tobra |
Mar 30 2006, 04:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
had that problem on a Super Beetle after the thing was vandalized(bent the wiper and turn signal arms down) Apparently the switch was damaged, never fixed it as it was very intermittent. Later Super Beetles had many extremely similar/identical parts to 914's
Lo-Fi Version | Time is now: 8th December 2025 - 06:27 PM |
