| toon1 |
Mar 29 2006, 10:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
what does the TPS act like when it is going out??
I still am chasing a bad hesitation/ miss and lack of pwer until 2700. By the way the car acts it seems like an elect. issue. |
| pfierb |
Mar 30 2006, 12:31 AM
oldest member ![]() ![]() ![]() Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Mine started to skip at a STEADY 2000rpm replaced the tps no help.Replaced the plugs,wires,dist.cap,points and condenser presto no more skipping. Take the tps apart and see if there is bad scoring on the contact arc if there is that could be the problem. |
| McMark |
Mar 30 2006, 02:32 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
TPS is a possibility. So are a lot of other things.
My experience (others will disagree with me) is that you should drop the stock FI now, and invest money into an aftermarket FI system like MegaSquirt. |
| toon1 |
Mar 30 2006, 09:01 AM
invest money into an aftermarket FI system like MegaSquirt. [QUOTE] The TPS looks ok, actually almost new but there's alway's that possibility. I will be going to megasquirt but it will be a while. I want to keep the car drivalble. |
| bd1308 |
Mar 30 2006, 09:37 AM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
my trigger point connections ( 3 pin at dizzy) was corroded and I had a HORRIBLE and HUGE bogging from 1200 to 2000 RPM.
timing maybe too. or mps going back, causing it to run real rich? b |
| JeffBowlsby |
Mar 30 2006, 10:03 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,207 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
To answer your question, this from Brad Anders excellent webpage:
More here: http://members.rennlist.com/pbanders/djetp...tm#troubleshoot |
| toon1 |
Mar 30 2006, 10:07 AM
forgot about checking the Brad Anders site, I have the pennington book it's good but limited.
Thank's Jeff |
| olav |
Mar 30 2006, 10:25 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Did you see the memo? You need to fill out a TPS report. |
| Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
To help you move in the MS direction....I'm going to give an older MS that was given to me. KenH was going to use it but I guess he's going to use carbs or a different aftermarket FI. I pass by LLNL everyday on my work...we can meet up for a coffee in the morning or later on in the day....lemme know.... |
| toon1 |
Mar 30 2006, 10:48 AM
that is an offer I can't refuse Sending PM |
Lo-Fi Version | Time is now: 13th March 2026 - 09:50 AM |
