| sk8kat1 |
Mar 29 2006, 11:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
ok I finally got my koni yellows on but they didn't seem to fit through the stock bushing up by the camber plate so I replaced it with the rubber pieces that came with the shocks ...
I guess it is a little late now but should they have fit with the org bushing and is it a bad thing that I removed the stock and replaced with the rubber that came with the shocks? mike |
| DanT |
Mar 29 2006, 11:09 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Why wouldn't you want to use the brand new rubber bushings/grommets?
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
| sk8kat1 |
Mar 30 2006, 12:08 AM
the others ones I had to actually cut them apart to get them off the car and then after the fact it seemed like such a PITA that I thought to my self ...hmmmm (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) ... maybe if it was that hard to take off , maybe it wasn't supposed to come off..
you know the you don't know for sure but it seems right situation.. |
| DanT |
Mar 30 2006, 12:15 AM
those were probably the 30+ year old originals. Hard as a rock and fused together. As you could see from the new ones they are supposed to be separate.
we are talking about the rubber dougnuts...right? |
| sk8kat1 |
Mar 30 2006, 06:56 AM
yup and yup they were one solid rubber piece w/ a steel shank ...
| Van914 |
Mar 30 2006, 08:01 AM
Van914 ![]() ![]() ![]() Group: Members Posts: 702 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest
Are you doing the front or rear?
| sk8kat1 |
Mar 30 2006, 08:54 AM
I was doing the front shocks rears on their way
| sj914 |
Mar 30 2006, 10:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
I don't think the fronts use the rubber donut pieces up front. At least when I replaced mine with yellows I didn't have them or used the one's that came with them. You got pics of the pieces that you took off the car?
| sk8kat1 |
Mar 30 2006, 10:32 AM
Lo-Fi Version | Time is now: 7th December 2025 - 04:23 AM |
