Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
when you remove the enrichment chokes on an IDF, and use blockoff plates, do you pull the 2 "piston" shaped things from inside that cavity?
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
I know I'm not alone, but I always thought it would be kinda cool to set up a mini linkage set to both carbs to operate the chokes. You could run a choke cable and really make startup/warmup a lot easier. |
Aaron Cox |
seen it done. IIRC kevin has autoloc door actuators to pull his chokes. very smart... now find me my IDF answer!!! |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Left plunger thingys onmy 40IDF's put the block off plates on works good as the plungers are spring loaded to stay in the normal running position. can't lose the parts this way either or forget how it supposed to go back together.
Warm up ??? hell it's already warm down here. |
Aaron Cox |
and by taking them out, the carb would be UNGODLY RICH???? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
that wasn't my car aaron. wish it was. neat setup. i guess a dual manual choke cable is sort of impractical. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
k Attached image(s) ![]() |
Aaron Cox |
so what happens if you remove the 2 "pistons" that live under that choke mechanism/blockoff plates?
rhodyguy |
i just pulled one of the cover plates off one of the 44s. there is nothing there. go dial in the carbs and linkage. don't throw the rest of the stuff away.
k |
Aaron Cox |
all the stuff is saved. thanks kevin. |
Lo-Fi Version | Time is now: 4th July 2025 - 03:59 PM |
