Front Suspension, Control arm stiff |
drive-ability |
Apr 1 2006, 08:06 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I am having a big problem with my control arms concerning bushing alignment. I have poly bronze bushings but when I tighten the control arm up it binds. My guess is the front end is bent/twisted. Any suggestions?
lagunero |
Apr 1 2006, 10:26 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
installed correctly, no parts missing? I believe Bleyseng wrote an install thread (maybe in the classics), check and compare. |
drive-ability |
Apr 1 2006, 10:56 PM
Poly bronze bushings aside, the problem predated the bushings. I think the alignment of the mounting points is off. I do have a V8 and have cut out the fender wells. I not saying the control arm wont move its just much tighter than it should be. I would think it would have a smoother action. The points are just binding, I guess I will need to install some struts from the shock towers down to the pan. I can weld in some threaded areas so I can push or pull the alignment back to where it should be. |
Aaron Cox |
Apr 1 2006, 11:29 PM
i think bleyseng shimmed his with washers....
Lo-Fi Version | Time is now: 23rd May 2024 - 12:58 AM |
