I am having a big problem with my control arms concerning bushing alignment. I have poly bronze bushings but when I tighten the control arm up it binds. My guess is the front end is bent/twisted. Any suggestions?
lagunero
Apr 1 2006, 10:26 PM
installed correctly, no parts missing? I believe Bleyseng wrote an install thread (maybe in the classics), check and compare.
drive-ability
Apr 1 2006, 10:56 PM
QUOTE (lagunero @ Apr 1 2006, 08:26 PM)
Poly bronze bushings aside, the problem predated the bushings. I think the alignment of the mounting points is off. I do have a V8 and have cut out the fender wells. I not saying the control arm wont move its just much tighter than it should be. I would think it would have a smoother action. The points are just binding, I guess I will need to install some struts from the shock towers down to the pan. I can weld in some threaded areas so I can push or pull the alignment back to where it should be.
Aaron Cox
Apr 1 2006, 11:29 PM
i think bleyseng shimmed his with washers....
