> Clutch questions, are they the same?
Hammy
post Apr 6 2006, 07:59 PM
mr. Wonderful
I've finally separated the transmission from the (old) engine. I have a replacement (new, to me) engine to go in. Both are 1.7's. The new to me/replacement 1.7 is from a 71, and the old 1.7 (and trans) are 73.
Is there any difference throughout the years with clutches/pressure plates/flywheels, or are they all the same?
I'm at a standstill because I don't know if I need to use the clutch stuff from the old engine and put it on the replacement engine.
As you can tell I don't know much about this stuff so keep it simple.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Thanks for any help
Replies(1 - 3)
SLITS
post Apr 6 2006, 08:24 PM
"This Utah shit is HARSH!"
The /4 friction disk had 4 springs and the "upgrade" had 6 springs (from the nineleben).
The /4 pressure plate was rated at 960 lbs, but when they went to the 2.0 /4, it was rated at 1200 lbs (numbers are from memory, but should be close)
With that said, they are all the same and will retrofit and forward fit.
Ta Da (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Hammy
post Apr 6 2006, 10:16 PM
mr. Wonderful
Cool, thanks Ron (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Ok, now how do I determine which parts to use, in terms of wear and which is in best condition? Anything to look for?
SLITS
post Apr 6 2006, 11:40 PM
Flywheel: Look for bluing (heat marks), cracking & radial grooves.
Friction disk: Springs not loose, material not deteoriating, and most of all, material left on disk.
Pressure plate: fingers are equal height in circle, no bluing / cracking of face. You would be hard pressed to check the amount of pounds required to depress the fingers.
Take pictures of the items and post them here for opinions.
- Lo-Fi Version Time is now: 5th March 2026 - 05:43 AM
