| vesnyder |
Apr 9 2006, 08:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Take a look! This is after only an hour? And when I am driving on the freeway (and oil pressure is high) I see a constant stream of smoke coming from under the engine hood. The encouraging thing is none of it is transmission fluid. My plan is to pull the engine and fix what I can, or at least the ones I know about. I already put new valve covers on - I am thinking the oil pump, oil cooler and push rod tubes - anything else I should look into? At least I rarely have to change the oil - I have a constant flush??
| vesnyder |
Apr 9 2006, 08:34 AM
Here's the pic ...
| Katmanken |
Apr 9 2006, 09:05 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Pushrod tube seals...
They tend to leak and can be replaced without pulling the heads... They drip on the heat exchanger and can caue a lot of smoke. Do a search... fix them right or they leak. Ken |
| drewvw |
Apr 9 2006, 09:54 AM
new england car guy ![]() ![]() ![]() Group: Members Posts: 1,632 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I don't know if this applies to the type 4 case but.... I had a similar problem with my ghia a few years ago. The type 1 case is a split case and some of the bolts had loosened and cause leaks across in many places like yours. Tightened 'em up and was good to go. |
Lo-Fi Version | Time is now: 17th June 2026 - 06:22 AM |
