Full Version: Help! I sprung a leak ...
vesnyder
Take a look! This is after only an hour? And when I am driving on the freeway (and oil pressure is high) I see a constant stream of smoke coming from under the engine hood. The encouraging thing is none of it is transmission fluid. My plan is to pull the engine and fix what I can, or at least the ones I know about. I already put new valve covers on - I am thinking the oil pump, oil cooler and push rod tubes - anything else I should look into? At least I rarely have to change the oil - I have a constant flush??
vesnyder
Here's the pic ...
Katmanken
Pushrod tube seals...
They tend to leak and can be replaced without pulling the heads...
They drip on the heat exchanger and can caue a lot of smoke.
Do a search... fix them right or they leak.
Ken
drewvw
I don't know if this applies to the type 4 case but....
I had a similar problem with my ghia a few years ago. The type 1 case is a split case and some of the bolts had loosened and cause leaks across in many places like yours. Tightened 'em up and was good to go.
