jflash914 |
Member ![]() ![]() Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 ![]() |
We have a strange electrical problem on my sons 75 six conversion. With the engine running you can hear the flasher relay clicking slowly (should not be activated at this time) and when you put on either turn signal the bulbs flash extremely fast. Also if you set the emergency brake the red light in the gauge rapidly flashes with the engine running. If you shut the engine off and leave the ingition on all turn signals and emergency brake light flash normally. We checked grounds by the fuse panel, engine bay , transmission strap, front trunk area etc. and all are good. We checked bulbs and tried a new flasher relay and still the problem exists. We tried disconnecting the emergency brake bulb and also the turn signal bulbs in the gauges but that didn't help. We disconnected the tach and the problem was still there. Has anyone ever experienced this problem? I was hopeing DD could shed some insight into this issue.
Thanks!!! |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Just a quick thought. the red flasher light for the parking break is a simple circuit. The wire grounds out throught the switch under the drivers seat that the handle contacts. Just a ground to check. They both work off of the flasher relay. Wish I could help more, but I gotta study so at least you got a (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Racing916 |
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,202 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
What are the voltages to ground at the terminals of the flasher?
Terminal 31 is ground Terminal 49 is 12v. Do these voltages change with the engine on or off? Also, what is the voltage at terminal 49A with engine on or off? Does the turn signal lamp in the tach flash when the flasher is blinking slowly with the engine on? Spoke |
Racing916 |
Spoke and Dr. Evil thanks for the suggestions, we will try them out and let you know.
Thanks! Steve |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Sorry, no thoughts to add at this time. Keep going through the system, checking things. Grounds, fuse connections (are the fuses OK? ends of fuses and/or holders clean?) and so on.
--DD |
jflash914 |
Spoke, No, the lamp does not flash when the flasher is blinking slowly with the engine running. I also had the engine running and turned off the lights in the garage and looked to see if any lights through out the entire car were dimly lit or flashing and could not see anything but still heard the flasher relay clicking. Thanks |
Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
If the dash lights flash when the car is on and the parking brake is engaged, I think that is normal, or I hope so, because that is what mine does, may have to hit reset button on master cylinder.
I had all sorts of turn signal issues, replaced the relay and it fixed it, used a 4 prong relay from a 69-70 VW bus($10 at local shop, vs more than twice that for the "Porsche" one from pelican, no offense DD) Plugs into the fuse block. I also could hear the relay click, and was told that meant it was working, which it turned out not to be. My contacts in the signals were all oxidized a bit too, used a pencil eraser to freshen them up a bit. One of my bulbs had a very attenuated filament, for whatever reason. |
Lo-Fi Version | Time is now: 31st July 2025 - 03:28 AM |
