Front mounted Fuel pump |
Tobra |
Apr 9 2006, 07:48 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Went to change out the fuel hoses under the tank, I knew I heard the fuel pump up there, it is sort of funky. Really short, twow hoses attached to one end, with the generic box fuel filter. Does it look familiar to anyone? Sorry about the bad pic, this was the best one.
Silvery looking deal is where the power attaches. Attached image(s) |
GeorgeRud |
Apr 9 2006, 08:08 PM
That is the common fuel pump relocation kit, it fixes a vapor lock situation that occurs with the fuel pump back by the ingine on a hot day. The last years of production had the fuel pumps relocated to the front trunk by the factory, but this looks to be an owner installed relocation.
Tobra |
Apr 9 2006, 10:06 PM
Judging by the hoses on it, it was done many moons ago, it is a funky looking little pump, never seen one like it.
DanT |
Apr 9 2006, 10:19 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Better like this (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Attached image(s) |
Tobra |
Apr 10 2006, 09:00 AM
That is better (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) way better, did you put louvers in the bottom of the spare well under that coooler? If yours is in the trunk, and mine is under it, in the MC hole with the spider webs and black widows, why does your pump look like that, and mine is nice and black. Didja pull that off a wreck that had it mounted like mine?
What size are those fuel hoses This post has been edited by Tobra: Apr 10 2006, 09:02 AM |
jhadler |
Apr 17 2006, 01:56 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Dan,
That's a nice setup, and I think I may wind up with a very similar arrangement. Tried to route all the AN6 lines to the pump as it was mounted under the steering rack, and there was no way everything was gonna fit. Do you think there's any vapor-lock kindof problem with the fuel lines wrapping over the hot oil lines? Yeah, I think my setup will look very similar. Even the towing light harness running along the left side... (IMG:style_emoticons/default/biggrin.gif) -Josh2 |
badeyeben |
May 20 2006, 06:47 AM
Newbie Group: Members Posts: 1 Joined: 3-May 06 From: Georgia Member No.: 5,970 |
Lo-Fi Version | Time is now: 4th June 2024 - 10:58 AM |
