Putting in the steel lines tonight, any advice on bending? |
drewvw |
Apr 10 2006, 12:19 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I have some steel brake line I am going to use for the engine fuel lines and I bought a pipe bender. Any advice (angles, best practice, etc) out there before I start? Looks pretty straightforward but I've never done the bending before.... |
ClayPerrine |
Apr 10 2006, 12:21 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Don't get in a hurry. Its easy to kink the line if you try to rush it.
Just take it slow and make the bends a little at a time. Make your bends less than they need to be, and creep up on the actual angle. Bending the tube back fatigues it and could make it crack. Good luck. |
Jaiden |
Apr 10 2006, 01:03 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
Yeah make sure you don't get your line caught on your wiring harness (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Ask me how I know!!! (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
drewvw |
Apr 10 2006, 01:06 PM
Thanks for the advice you guys....
I was thinking about the approach in my sleep last night. I think I am going to put one 60 degree bend in to start (to route it under the battery tray - no battery ) and then probably a 90 to connect it to the fuel pump and return line. Not sure if mine are setup like original, they were done once before and looks pretty easy to just plug in the steel to the rubber there. And yes, the rubber lines look okay.... |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:57 AM |
