Suspension shopping list, 72 1.7 |
BK911 |
Apr 17 2006, 09:47 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Hello,
The rear of my car is sitting about 22" from the fender arch to the floor. I assume the springs are worn out. The struts are definitely worn, I get sea sick driving over bumps. So it's time for a suspension overhaul. This car will never see the track, and probably won't even do an autocross. I wouldn't mind upgrading a little, but nothing drastic. Primarily a daily driver. So, what does the board recommend? Please help me compose a shopping list. Also, where do you guys buy your parts from? Thanks, BK I just searched around. It looks like the prefered struts are Koni/Bilstein/Boge, in that order. Then 140# springs, turbo tie rods and call it a day. I have a set of f/r sways from a 70 911. Will they bolt right on? Thanks again. |
Eric_Shea |
Apr 17 2006, 11:02 AM
QUOTE I just searched around. It looks like the prefered struts are Koni/Bilstein/Boge, in that order. Then 140# springs, turbo tie rods and call it a day. I have a set of f/r sways from a 70 911. Will they bolt right on? Looks like you've got it sussed. Front sway is the same but the droplinks are about 1" longer (I can't remember, longer or shorter... I think longer) than the 911 counterparts. The rear will not bolt up. For the rear you'll need to find a 914 bar along with the shock bolts that have the ball on them. Get a complete setup. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:54 AM |
