| WRX914 |
Apr 17 2006, 02:48 PM
2.5 WRX STI hybrid powered beast ![]() ![]() ![]() Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
I am down to what seems to be the biggest pain in the butt. I am attempting to install the drivers and passenger door window seal kit (with fuzzies). I have an aluminum channel that screws (bolts) to the inner part of the door. The old fuzzies just slid right out of it's channel, but when I tried to replace it with the new fuzzy, I am having a real hard time getting the new fuzzy to slide in the channel. Any ideas? Also, does anyone have an installation diagram showing what seals and fuzzies go where? As always, any help is greatly appreciated.
Keith |
| So.Cal.914 |
Apr 17 2006, 03:01 PM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Well when I did mine I used rubbing alcohol in the channel and on the part. It helps the rubber slide and when you are done the alcohol evaporates. (IMG:style_emoticons/default/smoke.gif)
| LvSteveH |
Apr 17 2006, 03:35 PM
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Silicon or glycerin work well. The best tip I can offer is to make sure the channel is nice and clean and free of bends or deformities. That applies to most of the rubber seal channels as well. The extra time spent making sure everything is straight is well worth it.
| WRX914 |
Apr 17 2006, 03:54 PM
The fuzzies actually have a woven backing on them. I am not having troubles with the rubber components, just the fuzzies. Pics?
| MarkV |
Apr 17 2006, 04:53 PM
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
The outer fuzzie is mounted on a alluminum channel that is attached to the door with some tiny phillips head screws. There are three or four holes under the innner fuzzie that give you access to the screw heads to the outer fuzzies. The screws are in holes on the face of the fuzzy and are a pain to get out. Mine were rusted solid. Use some PB Blaster on them before you try to remove them. Once you get the alluminum channel out the fuzzie slides out of the channel. (IMG:style_emoticons/default/confused24.gif)
| WRX914 |
Apr 18 2006, 12:39 PM
The outer fuzzie is mounted on a alluminum channel that is attached to the door with some tiny phillips head screws. There are three or four holes under the innner fuzzie that give you access to the screw heads to the outer fuzzies. The screws are in holes on the face of the fuzzy and are a pain to get out. Mine were rusted solid. Use some PB Blaster on them before you try to remove them. Once you get the alluminum channel out the fuzzie slides out of the channel. (IMG:style_emoticons/default/confused24.gif) Got all of that done... I just need assistance in advising how the new fuzzies "slide"back in. my fuzzies seem to be just a RCH too wide to slide down the channel. Any hints as to how to slide the new fuzzies back in the old channel? (IMG:style_emoticons/default/confused24.gif) |
| MarkV |
Apr 18 2006, 01:20 PM
Got all of that done... I just need assistance in advising how the new fuzzies "slide"back in. my fuzzies seem to be just a RCH too wide to slide down the channel. Any hints as to how to slide the new fuzzies back in the old channel? (IMG:style_emoticons/default/confused24.gif) I haven't done that step yet. I have the new fuzzies & haven't installed them. Try some spray silicone. |
| markb |
Apr 18 2006, 01:53 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Got all of that done... I just need assistance in advising how the new fuzzies "slide"back in. my fuzzies seem to be just a RCH too wide to slide down the channel. Any hints as to how to slide the new fuzzies back in the old channel? (IMG:style_emoticons/default/confused24.gif) I haven't done that step yet. I have the new fuzzies & haven't installed them. Try some spray silicone. I'm also attempting the fuzzies today. Pain in the butt! I haven't been able to get one more than a quarter of the way on, and that's using some rubber care to help it slide. |
| WRX914 |
Apr 18 2006, 04:27 PM
Certainly someone has done this and can offer some help...
| Toast |
Apr 18 2006, 05:15 PM
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Lubercation baby.
(IMG:style_emoticons/default/biggrin.gif) |
| Eric_Shea |
Apr 18 2006, 06:55 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Damn it Toast... knock it off!
| markb |
Apr 18 2006, 08:26 PM
Damn it Toast... knock it off! (IMG:style_emoticons/default/agree.gif) Now I gotta go take a cold shower.... (IMG:style_emoticons/default/biggrin.gif) |
| markb |
Apr 20 2006, 10:32 AM
Anybody gotten their fuzzies on yet? I can only get mine in half way. (IMG:style_emoticons/default/confused24.gif)
Geez, I can just see the comments coming in on that sentence. (IMG:style_emoticons/default/biggrin.gif) |
| WRX914 |
Apr 20 2006, 12:27 PM
Not yet, I am beginning to do damage to the webbing backing. I think I will bring it to a local metal worker and see if we can open the aluminum channel, insert the fuzzy and clamp the channel back down...
| markb |
Apr 20 2006, 01:48 PM
I understand your frustration. I've tried a couple of different lubricants, tried spreading the channel a little, even brute force & ignorance didn't work. (IMG:style_emoticons/default/biggrin.gif)
| WRX914 |
Apr 20 2006, 02:45 PM
Lemme guess, you got the fuzzies from AA?
I have contacted a very well known hot rodder here in Vegas, he told me that we will definately be able to get the fuzzies on one way or another... I think we will have to open the "C" channel and insert the fuzzy and then clamp it back into place... Keith Let me know what your plans are... |
| WRX914 |
Apr 29 2006, 09:18 PM
| markb |
Apr 29 2006, 09:51 PM
I finally got mine on by using the handle of a pair of pliers (or something else that won't tear the fabric, but will bend the metal), and bent the back side of the strip a little. It then slid into the channel with a little work. Only do about three inches at a time. (IMG:style_emoticons/default/smile.gif)
| davesprinkle |
Apr 29 2006, 11:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None
You can't slide the seal into place -- you've got 2 feet of rubber-on-metal friction working against you. Also I found that any attempt to slide the seal into the holder tended to tear the fabric backing. I successfully installed mine by just prying the seal into place with the tip of a blade screwdriver. Just put one side in and use the blade to press the other side into place. Just work your way from one end of the other, pressing in 1/4" of the seal at a time.
I don't suggest opening and re-crimping the holder. You might work-harden and crack the aluminum. |
| rhodyguy |
Apr 30 2006, 08:04 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i like your bike dave.
k |
Lo-Fi Version | Time is now: 19th June 2026 - 03:55 AM |
