Replacing Rear Engine Seal, How do you remove fan hub?? |
vesnyder |
Apr 19 2006, 06:16 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am replacing the rear engine seal and need to remove the fan hub (or do I) - pictured below. How does this come off? The Haynes manual is useless!
Looking at the photo, do you think that is my leaking problem? I will also be replacing the oil pump gasket |
vesnyder |
Apr 19 2006, 06:35 PM
Found the answer - a gear puller. How about reinstalling??
Mueller |
Apr 19 2006, 06:42 PM
you do know that the fan is at the front of the engine?????
you have to remove the flywheel to replace the rear engine seal......... |
JoeSharp |
Apr 19 2006, 06:45 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Instlation is the reverse of removal. Line up the key-was and slip it in place and SMACK it with the gear puller and tourque it to spec... (IMG:style_emoticons/default/biggrin.gif)
:PERMAGRIN: Joe |
Lo-Fi Version | Time is now: 14th June 2024 - 06:32 AM |
