Adjustable Brake Proportioning Valve, Recommendations and experiences ... please |
Eddie914 |
Apr 20 2006, 05:35 PM
Unregistered |
In preparation for installation of the 3.2 into the teener, I'm cleaning up a few items: New SS fuel lines, welding the broken clutch tube, front oil cooler thermostat and brake proportioning valve.
I'm planning on replacing the stock proportioning valve with a "T" and installing an adjustable valve. What type/brand of valve do other teener owners use? The Good? The Bad? The Ugly? Lever type ... Wilwood? Knob type ... Wilwood or SBC or ? Thanks Eddie |
Eric_Shea |
Apr 20 2006, 06:28 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What brakes are you using?
JWest |
Apr 20 2006, 06:33 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Rough_Rider |
Apr 20 2006, 06:51 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
I've the lever style one. It works fine however it only has 5 or 6 detents. Plus when adjusting more to rear the feel goes from a positive click to loose. A couple of times on bumpy track the lever has jumped to full rear brakes, which lead to rear lockups.
IMO go with the twisty type. so long as it holds its position. |
Eddie914 |
Apr 20 2006, 07:12 PM
Unregistered |
Eric,
911SC front & rear calipers and rotors Porterfield R4 pads Front: 225/50/16 on 16 x8 Rear: 245/45/16 on 16 x 9 Thanks Eddie |
Eric_Shea |
Apr 20 2006, 07:34 PM
You may not need one with that set-up but you probably have enough rear brake to warrant one if you want one... I kinda like the set-em and forget-em kind that can take the place of the T.
I use a T with a similar set-up. |
Eddie914 |
Apr 20 2006, 09:30 PM
Unregistered |
Thanks All!
Just ordered a "T" and adjustable proportioning valve from JWest Engineering. Eddie |
JWest |
Apr 20 2006, 09:54 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 09:41 AM |
