Wiper switch assembly, I have 2 extra wires on the replacement |
Allan |
Apr 23 2006, 11:53 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Trying to swap my bad wiper assenbly with a replacement someone sent me.
The problem is, the new one has 2 extra wires and because of this the connector is bigger and wont slide into the column. Can I modify it and get ris od the extra wires? I'm guessing they are for intermittent and electric pump. Old Attached image(s) |
Allan |
New
Attached image(s) |
Allan |
Apr 23 2006, 12:39 PM
Update.
I traced the extra 2 wires and they were for an electric pump. Got rid of them and then I was able to swap over the connector housing and everything went in fine. Only problem, the wipers still don't work. (IMG:style_emoticons/default/headbang.gif) Is there a relay that goes bad? All the fuses are good. |
Aaron Cox |
Apr 23 2006, 12:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
oh you suck.... ive been looking for one that supports a pump and you kill it.
bust out der haynes manual |
Allan |
Apr 23 2006, 12:47 PM
[quote name='Aaron Cox' date='Apr 23 2006, 11:42 AM' post='665687']
oh you suck.... ive been looking for one that supports a pump and you kill it. I don't know how you would get it to work without doing some serious mods on either the assembly or the console housing plus you would have to change out the connector going into the harness under the dash. Not something I would wanna try. (IMG:style_emoticons/default/blink.gif) |
Allan |
Apr 23 2006, 03:20 PM
Okay, all back together.
I didn't screw around trying to get the wipers to work but at least I fixed the potential fire problem. Got rid of the 944 steering wheel while I was at it... Attached image(s) |
ThinAir |
Apr 23 2006, 05:23 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
On my '73 the relay is the round relay at the far left that is mounted to the top side of the fuse box. My wipers stopped working for awhile and putting a new relay here fixed my problem.
Qarl |
Apr 23 2006, 05:32 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Yes... that is the typical 924 wiper with the extra wires for the pump.
You did correct in switching over the plastic housings to get it to fit. You can use the extra wires for the electric pump or to activate passenger ejection device. If you wipers stopped working a) fuse (IMG:style_emoticons/default/cool.gif) relay c) you put the wires back in the incorrect order |
Lo-Fi Version | Time is now: 7th June 2024 - 03:07 PM |
