914 2.0L, NEED HELP |
Mr_Chu |
Apr 24 2006, 08:48 PM
Member Group: Members Posts: 58 Joined: 20-August 04 From: Bay Area, CA Member No.: 2,584 |
i'm going to start on restoring/upgrading my 74 2.0L soon.
I want to rebuild the motor, i've heard that you can bore/stroke out the stock 2.0L motor into a 2.4L beast.. is that true? how would i go about doing that? could i possibly piece together a turbo setup that would work? and i also want to improve suspension.. what kind is the best for the car? |
randyt914 |
Apr 24 2006, 08:53 PM
Member Group: Members Posts: 66 Joined: 6-April 06 From: truckee ca Member No.: 5,832 |
i'm going to start on restoring/upgrading my 74 2.0L soon. I want to rebuild the motor, i've heard that you can bore/stroke out the stock 2.0L motor into a 2.4L beast.. is that true? how would i go about doing that? could i possibly piece together a turbo setup that would work? and i also want to improve suspension.. what kind is the best for the car? go check out high performance house in red wood city if your on that side of the bay.... |
Mueller |
Apr 25 2006, 12:03 AM
check out aircooled technology for the motor questions, but in a nut shell, yes, you can make the motor bigger, it won't be cheap...there are some people here that have built them for a lot less but details are sketchy
as for the suspension, what do you have now and what are you plans? the stock suspension can be tweaked for very little that'll make it a world class handler...normally you make sure the safety related items are in good condition such as the ball joints and tie rods, then you move onto swaybar(s) and decent shocks and good tires. QUOTE could i possibly piece together a turbo setup that would work? I dunno, if you have to ask, then I'd say no, you cannot do it....once you read a book or 2 on the subject and do some more research and can fab/machine your own stuff, then yes.... |
anthony |
Apr 25 2006, 09:00 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Check out www.aircooledtechnology.com. They sell complete engine kits in 2056, 2270, and 2316 for 914s. They also have a turbo engine kit. 2.4L would result in an odd combo of parts. If you don't want to build one of the kits yourself you can also take it to your mechanic for assembly.
Lo-Fi Version | Time is now: 10th June 2024 - 12:19 PM |
