Die Electric Grease, Just for plug connections? |
Rog914 |
Feb 22 2003, 10:17 AM
914 Fanatic Group: Members Posts: 129 Joined: 5-January 03 From: Reisterstown,Md Member No.: 93 |
I've noticed on late model cars the electrical plug connections have die electric grease to prevent corrosion. Would it be ok to use it on our 914's knot only for plug connections, but for the relays, fuses & ground connections after cleaning them up? Is this a good or bad idea?
Thanks for any info, Ralph 74 2.0 |
Mark Henry |
Feb 22 2003, 11:37 AM
It will work, but it makes such a mess. I would only use it on the more corrosion prone connectors and bulbs.
GWN7 |
Feb 22 2003, 12:55 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
You can put it on everything....I have used it on door hinges, hood hinges (GMC coil types), trailer connectors, bolt threads..........anything you want lubed. It keeps moisture out and stops rust. Besides RTV, it's second in the top of my tool box.
Zeke |
Feb 22 2003, 05:53 PM
Never left, but not right.... Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
No, No. Don't put anything like DIE electric on a 914. Just the mere mention of the word might scare the car and it will die. (IMG:style_emoticons/default/cool_shades.gif)
Lo-Fi Version | Time is now: 12th June 2024 - 08:02 AM |
