K & H Air Filter Hose Connection |
AvalonFal |
Apr 29 2006, 08:30 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
PO installed a K&H air filter on my '74 2.0L. One of the hose connections was cut and plugged. Engine idles high. Could be the problem?? Anyone know the proper hose connections for the K&H??
I'm trying to attach a pic of the engine showing the hose plugged with a bolt (resting on oil fill cap). Hope the pic comes thru OK. |
srb7f |
Apr 29 2006, 09:33 AM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
I don't mean to insult you here, but have you tried the idle speed adjustment screw yet? It's located on the throttle body facing the airbox. Steve
Rand |
Apr 29 2006, 11:37 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
A filter element doesn't change the hose requirements.
For sure try screwing the idle adjustment in on the side of the throttle body. Fast idle would be caused by too much air getting in the intake. A leaky vacuum hose or open connector at the plenum below the butterfly can cause that. The hose you're talking about connects above the throttle body, so the plugged end in your photo wouldn't be the problem. I *think* that hose is for the AAR. The place you need to check for air leaks is the other end. If the AAR is gone, make sure the hole is blocked off air tight. If the AAR is present, make sure all the hoses are connected or taps are plugged air tight. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:43 AM |
