Handling quirk, What did I do now |
Joe Ricard |
May 1 2006, 06:30 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
SO I did a string alignment the other day. Needed to take out some camber to make better use of my SLICKS. Anyway I was playing around inthe high school parking lot yesterday sorta shaking the bugs out of new brakes and such.
The car seems to turn quicker and easier to the right vs the left. Camber is -1 degree on all 4 corners and toe is near zerofront and very slight toe in at the rear. CAR DRIVES STRAIGHT down the road. just when doing a slalom type manuever it seems to be quicker to the right. air pressure is the same both side shocks are the same both sides. Kinda screwy (IMG:style_emoticons/default/confused24.gif) |
Van914 |
May 1 2006, 06:34 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Can you say corner weights? Might be the problem or the sway bar needs adjusted for preload.
My guess, van914 |
URY914 |
May 1 2006, 07:13 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,968 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Body flex? (the car not yours)
Those slicks are transfering more load than ever into that 30 year old car. |
J P Stein |
May 1 2006, 07:15 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Check your rear toe thrust angle .
Joe Ricard |
May 1 2006, 07:30 AM
Check your rear toe thrust angle . OK JP ya got me there. How do I do that? Might be something to check with the sway bar pre load. How do I do that? do I need the wheelson the ground. How the hell do you get up in there. No slicks Paul, them only come out for race day. Car does it on regular streets too. Ahhh the fine art of suspension tuning. Well I am getting close enough to be able to tell the difference from one day to the next. Car is getting pretty nuetral and I was having one hell of a good time burning through a old set of Hoosiers. Yes you can get them all the way down to cords. with no grooves left. (IMG:style_emoticons/default/happy11.gif) OK so I did some reading.... Seems everything points to wierd things like this could be a result of crooked car. Well yea that could be as there is evidence of a drivers side front repair sometime in the past. Hmm good thing I got the stripper waiting off in the wings. |
URY914 |
May 1 2006, 08:00 AM
Check your rear toe thrust angle . Also, check the angle of your dangle. (IMG:style_emoticons/default/happy11.gif) |
ConeDodger |
May 1 2006, 09:15 AM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/w00t.gif) As long as the subject has already been brought up... A lame excuse for a hijack but I was going to post this in my own thread.
I just finished putting Koni Yellow Sports all the way around, Turbo Tie Rod Ends, Rack Spacers, 140 Weltmiester Springs in the rear on my car. The car is a 73 look 75 2.0 liter. It has sway bars front and rear of the factory flavor. My new Yoko A032R S Compound tires went on Saturday. I am about to take it to IPB for an alignment, and possibly corner weighting and such. Now for the questions... For autocross what settings do you guys shoot for? I always try to get as much negative camber as I can but what about the tow and caster on the 914? |
SirAndy |
May 1 2006, 09:43 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can you say corner weights? (IMG:style_emoticons/default/agree.gif) and what a difference that made ... i had the same thing, right turns OK, left turns understeer and trouble turning in. one corner balance later and all is gud now ... (IMG:style_emoticons/default/smile.gif) Andy |
Joseph Mills |
May 1 2006, 10:09 AM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Corner Balance. (IMG:style_emoticons/default/yellowsleep[1].gif) But since rear toe is set independently of wheels and to the car chassis centerline, it might be worth checking. Is that what JP said? (IMG:style_emoticons/default/biggrin.gif) .. |
Joe Ricard |
May 1 2006, 10:54 AM
Sumpin about angle of sumpin.
and Paul the perv wants to know how it's hangin. I've been holding off of corner balance becuse I am not done cutting off crap that is not needed. |
jhadler |
May 1 2006, 11:06 AM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
For autocross what settings do you guys shoot for? I always try to get as much negative camber as I can but what about the tow and caster on the 914? All the caster you can get up front. Typically, a good autox alignment (on DOT tires), will need a little toe out in front, a little toe in at the rear. And roughly 1.5-2 degrees negative camber front and rear. I'm giving you generalities because all cars are different, and all driving styles will need different setups. But these are good starting places. The stiffer the suspension, and the wider the wheels, generally the less static negative camber you'll need. -Josh2 |
jhadler |
May 1 2006, 11:09 AM
Sumpin about angle of sumpin. and Paul the perv wants to know how it's hangin. I've been holding off of corner balance becuse I am not done cutting off crap that is not needed. Thrust angle is possible, it's the difference between the direction the front wheels are pointing and the direction the rear wheels are poninting. Typically, a car with a thrust angle issue looks like it's crab walking, with the rear end always hanging off to one side or the other. But I'd say it sounds like a cornerweight issue there Joe. Especially if it's consistent reagardless of tires. Also check for sway bar prelaod as well. But corner weights are good place to start. Check the bushings too, if there's a blown bushing, that can create dynamic toe and camber changes that'll really be fun... -Josh2 |
messix |
May 1 2006, 11:30 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
you chassis is weight biased to the left, i surmize that there is a postierer containing an abundance on dense mass in the form of lead, this would seem to be from you desription to be about in the center of the polar rotational moment of the chassis, most likely low in the roll center.
it's the lead ass in the drivers seat! |
SirAndy |
May 1 2006, 11:39 AM
I always try to get as much negative camber as I can that entirely depends on your tires ... the goodyear schlicks don't like anything over -1. if you go further than that, they will stick much less and wear uneven real fast ... the difference in grip is very noticeable from -2 (so so stick) to -.05 (holy shit stick) (IMG:style_emoticons/default/smile.gif) Andy |
Joe Ricard |
May 1 2006, 12:25 PM
you chassis is weight biased to the left, i surmize that there is a postierer containing an abundance on dense mass in the form of lead, this would seem to be from you desription to be about in the center of the polar rotational moment of the chassis, most likely low in the roll center. (IMG:style_emoticons/default/finger.gif) Hardly @ 160 pounds with shoes shirt shorts and needing to take a dump. I'll look at the other things suggested. (IMG:style_emoticons/default/beer.gif) You guys crack me up. it's the lead ass in the drivers seat! |
Brando |
May 1 2006, 01:04 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Joe, are you left-handed or right-handed? (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 12:11 PM |
