Fresh air blower, ?? |
thesey914 |
May 1 2006, 09:52 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Just been installing my fresh air blower after paint. Its been ages since I took this out but here's my problem...
When the fan is off the cable that is attached is extended to maximum length which opens the vents in the blower housing....conversely when the fan is set to maximum the cable pulls the vents closed which blocks off the air supply and that can't be right. The cable has a riveted on support meaning it can only run one way. Anyone encountered this before and can point out where I'm making my bloomer? (IMG:style_emoticons/default/confused24.gif) |
jr91472 |
May 1 2006, 10:03 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
You're right, that sounds backwards to me. Did you take the blower assy apart while it was out of the car?
I replaced my blower about a year ago and it seemed to go right in. Can't recall any thing really tricky about it. sorry, not much help. |
thesey914 |
May 1 2006, 10:26 AM
well it's wired up correctly becasue fan speed is highest when pushed fully to the right (position 3).
Its the cable/vent assembly that is baffeling me at present. (IMG:style_emoticons/default/wacko.gif) |
tyler |
May 1 2006, 01:30 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
Make sure the cable you're hooking up is from the "blue" on the control face it should open the center air box vent when you move it all the way to the right.
The other two go to the left and right "defroster boxes" and control hot ait from the rear and cabin outlet vs defroster. It sound like you may have the wrong cable. |
SirAndy |
May 1 2006, 02:10 PM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) sounds like you got the cables mixed up. i marked mine before i took the assembly apart.
(IMG:style_emoticons/default/smile.gif) Andy |
Lo-Fi Version | Time is now: 10th June 2024 - 05:28 PM |
