Int. Wipers?, figures |
kenpolives |
May 4 2006, 01:39 PM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
I just got the fuel line under the tank finished, reinstalled etc, got both wiper speeds working (loose wire) and now my wipers go on every 6 seconds. (this poroblem was happening prior to the tank removal but thought fixed).
Ok, but I don't have int wipers (that I know of) it is a 74 but the switch has been changed a few times I am sure. Is 6 seconds the normal interval for int wipers?? if not what could be going on. I am unable to disengage the wipers by pulling the switch back or pushing it forward. Both speeds work fine. . Is my fix pulling the steering wheel and trying to move the switch then? Thanks |
bd1308 |
May 4 2006, 01:48 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I dunno but if you have int. wipers i'll offer money on that module....
b |
East coaster |
May 4 2006, 03:01 PM
Senior Member Group: Members Posts: 1,691 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Do you have a relay on the backside of th edrivers side cowl support bracket? ( the verticle orange bar in next to your fresh air box that I see in your avatar)
If you don't have a relay on the back of this bracket, you do not have intermittent wipers (or at least shouldn't). |
kenpolives |
May 4 2006, 03:05 PM
Do you have a relay on the backside of th edrivers side cowl support bracket? ( the verticle orange bar in next to your fresh air box that I see in your avatar) If you don't have a relay on the back of this bracket, you do not have intermittent wipers (or at least shouldn't). Relay is there, and so is a broken wire.... problem fixed. thanks |
Lo-Fi Version | Time is now: 9th June 2024 - 07:16 PM |
