Tow Hooks anyone?, Designed my own |
RON S. |
May 17 2006, 01:15 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I felt I needed some towhooks on my car,if I ever get a chance to track it.
I looked at all that is offered,and felt that what is available retail was just to plain. So,I designed my own folding set,even did a lift test to make sure everthing worked ok.had'm powdered,and WaLa. Next on the to-do's.Installing a 930 front floating brake setup I recently acquired. Ron Attached thumbnail(s) |
RON S. |
Nudder
RON S. |
May 17 2006, 01:17 PM
Nudder 1
RON S. |
May 17 2006, 01:18 PM
last 1
Andyrew |
May 17 2006, 01:25 PM
Where on the body do they mount to?
MartyYeoman |
May 17 2006, 01:28 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Those look tiny.
I'd be very afraid. |
Andyrew |
May 17 2006, 01:32 PM
They are plenty large for simple towing on the track, on the highway or a strap to tie down, definately not. (and definately not for a dyno..)
My concern is that it is simply mounted to the bumper. Good way to rip off a bumper, bumper mounts, and screw up your car royally... Andrew Just looking out for you bud! They do look pretty though! (IMG:style_emoticons/default/smile.gif) |
RON S. |
Where on the body do they mount to? On the fronts,they are mounted to a formed and gusetted bracket,that bolts to the A-arm pickups.Pretty much like a Weltmeister setup that I recall them selling. The rears are bracketed & gusetted on each side same area as the original towhook. Ron |
URY914 |
May 17 2006, 01:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Show us with the bumpers off.
Andyrew |
May 17 2006, 01:37 PM
Hmm I think it might work.
but I think you should show us with the bumpers off. |
Aaron Cox |
May 17 2006, 01:39 PM
QUOTE My concern is that it is simply mounted to the bumper. Good way to rip off a bumper, bumper mounts, and screw up your car royally... his bumpers are fiberglass andrew (IMG:style_emoticons/default/smile.gif) |
Andyrew |
May 17 2006, 01:40 PM
Aaron... I know...
which is a reason I was really concerned... lol but ya.. you wont tear a bumper mount with fiberglass bumpers... |
Cap'n Krusty |
May 17 2006, 02:01 PM
They're useless as tiedowns, because you tie down to something that isn't sprung, like a wheel or the control arm. The Cap'n
RON S. |
May 18 2006, 05:38 AM
Show us with the bumpers off. Hmm I think it might work. I did a final lift test on each Individual hook by hooking a chain to an engine hoist,at only 1 hook,then lifting that end of the car off the ground by a foot & a half,and then dragging the car around the shop to see if any flex occurred. but I think you should show us with the bumpers off. I'll slip the rear bumper & front valence off this evening,and pop a couple pics of the "Hidden support structure".That'll explain it all. They're useless as tiedowns, because you tie down to something that isn't sprung, like a wheel or the control arm. The Cap'n Every hook is fastened to something that isn't sprung.The front hooks are bracketed to the front A-arm mount points. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:44 AM |
