She ran! and a gasket question |
Hammy |
May 17 2006, 11:04 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I'm thrilled.
Started it up for the first time tonight, and I put it in and hooked it all up myself. Finally gave up with my solenoid trouble and went out and bought a new starter yesterday. (60 bucks with lifetime warranty) Now she turns right over Hooked up the carbs and linkage and at first couldn't get it to fire and that was a downer. After some looking around found out I had the fuel pump wired backwards (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) Turn the key.. heard it fire a couple of times and then she comes to life... (IMG:style_emoticons/default/biggrin.gif) Freakin' loud without the muffler on (IMG:style_emoticons/default/aktion035.gif) Anyways, I need to get some new gaskets for inbetween the heads and the carb manifolds. Is there anything specific I need to buy (size) ?? TIA. |
bd1308 |
May 17 2006, 11:07 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
contgrats!! (IMG:style_emoticons/default/clap56.gif)
nope..Look for intake gaskets. Get the fiber ones not the dumb metal ones. 1.7 is four bolt so you'll obviously need the 1.7/1.8 type gasket. Thats about it. b |
rhodyguy |
May 17 2006, 11:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i think mentioned that during the rambling discussions. i was positive when i heard gurgling at the gas tank when the key was turned on. i used the stock phelonic f.i. blocks under the intakes, hoping to prevent some of the heat soak.
k |
bondo |
May 17 2006, 11:42 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Those gaskets are near new, and the phenolic part of them is still good. I say just clean off the paper gasket material, smear some RTV on them, and install them. You could go to the trouble of cutting new paper gaskets, but I don't think it's necessary. I'm pretty sure the paper gaskets are not available separately, and the assemblies are kinda pricey, for gaskets.
Hammy |
May 17 2006, 11:49 PM
Those gaskets are near new, and the phenolic part of them is still good. I say just clean off the paper gasket material, smear some RTV on them, and install them. You could go to the trouble of cutting new paper gaskets, but I don't think it's necessary. I'm pretty sure the paper gaskets are not available separately, and the assemblies are kinda pricey, for gaskets. Alright, thats what I did, just took off the paper part. What is RTV? |
bondo |
May 18 2006, 12:38 AM
Those gaskets are near new, and the phenolic part of them is still good. I say just clean off the paper gasket material, smear some RTV on them, and install them. You could go to the trouble of cutting new paper gaskets, but I don't think it's necessary. I'm pretty sure the paper gaskets are not available separately, and the assemblies are kinda pricey, for gaskets. Alright, thats what I did, just took off the paper part. What is RTV? Room temperature vulcanizing sealant.. Fancy name for silicone. (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
May 18 2006, 07:45 AM
(IMG:style_emoticons/default/rolleyes.gif) the blocks are only $8.75 for the 1.7/1.8 and $12.75 for the 2.0 (from the bird). using rtv is a poor product application imho. if you should EVER have to pull the intakes, it's going to be a pita cleaning everything up just to reseal with the goop, and if for some chance they don't seal completely, repeat, repeat....using the blocks will push the intakes out/sideways a bit, but you can make up for this with a simple linkage adjustment. you don't need no stinkin rtv.
k |
Cap'n Krusty |
May 18 2006, 07:58 AM
At 60 bucks for a "rebuilt" starter, you're gonna need that "lifetime" warranty. Good part about it is you'll become really good at starter R&R! The Cap'n
bondo |
May 18 2006, 09:54 AM
(IMG:style_emoticons/default/rolleyes.gif) the blocks are only $8.75 for the 1.7/1.8 and $12.75 for the 2.0 (from the bird). using rtv is a poor product application imho. if you should EVER have to pull the intakes, it's going to be a pita cleaning everything up just to reseal with the goop, and if for some chance they don't seal completely, repeat, repeat....using the blocks will push the intakes out/sideways a bit, but you can make up for this with a simple linkage adjustment. you don't need no stinkin rtv. k I disagree.. The old ones had no RTV. The paper gasket part had been sucked into the intake in several places, and left nice gaps which I could see the backfires (caused by the massive vacuum leaks) through. With paper gaskets or not, I use RTV now. Each side has 4 places for possible leaks, and that's too many to rely on the clamping pressure of 4 bolts. |
Lo-Fi Version | Time is now: 6th June 2024 - 01:35 PM |
