914 overheating or runs hot |
lilly4324 |
May 18 2006, 05:42 PM
Newbie Group: Members Posts: 8 Joined: 17-November 05 From: oakley,CA Member No.: 5,144 |
I put a 1.7 muffler on my 2.0 motor will i loose power and tend to run hot?
Brad Roberts |
May 18 2006, 05:44 PM
Unless you do some serious cutting and grinding.. you wont be installing a 1.7 muffler on the back of a set of 2.0 heat exchangers.
The 2.0 muffler mounting is physically wider than the 1.7. They dont line up. B |
bd1308 |
May 18 2006, 05:46 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
the exhaust as a whole (Heat exchangers AND muffler) must be switched out, so you had a 1.7 system to begin with. I didn't have any problems at all with my 1.7 system on a 2.0L engine. There could be a issue with slightly reduced power output (depends on muffler choice mostly IMO) but from what I understand, the stock system isn't the "best" system if you're looking for performance. With a aftermarket system, you will gain power but may lose heat capability.
b PS= the other thing that could happen is what Brad said, IE it actually is a 2.0 muffler. You'll know right away if they wont work. b |
Lo-Fi Version | Time is now: 6th June 2024 - 02:53 PM |
