6 cyl Marelli's and electronic ignitions, can I put a crane xr700 in there |
2teeners |
Feb 23 2003, 08:55 PM
Member Group: Members Posts: 79 Joined: 2-January 03 From: Arlington DFW, TX Member No.: 78 |
I heard you can't fit aftermarket point replacement stuff into the 6 cyl marelli distributors, and the bosch replacements are tough to come by. What would be the best option to improve on the point setup?
Thanks in advance. |
Brad Roberts |
Feb 23 2003, 09:25 PM
Crane sells a specific XR700 version for 6cyl Marrelli dizzy's. I should have one in my posession sometime this week.
B |
2teeners |
Feb 23 2003, 10:07 PM
Where can I get one? Is there a part no. ?
mskala |
Feb 23 2003, 10:13 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
QUOTE(Brad Roberts @ Feb 23 2003, 10:25 PM) Crane sells a specific XR700 version for 6cyl Marrelli dizzy's. Is this true? I probably won't be getting one of those very soon because I have an old prototype from Allison which has the vane and optics holder that I needed to hook up the Bosch CD. But it would be nice to know I can get something to fit in there for my spares (which are still points). Mark S. '70 914-6 prototype optical marelli homemade 'lectronic rev-limiter homemade imitation G-meter |
Brad Roberts |
Feb 23 2003, 10:20 PM
1968-1976 (7**) 6 Cylinder - w/Perma Tune CD (To Convert Points & Trigger CD) To replace points with electronic pickup to trigger stock Perma Tune CD. Use point output optical trigger Pt. No., 715-0020 with installation kit Pt. No., 700-2231. With this setup the stock tach will still work as it did stock.
7**. If you replace the Perma Tune with our XR unit the stock tach will not work. Asshole alert: use the web guys (lol) http://www.cranecams.com/ignition/intro.htm B |
mskala |
Feb 23 2003, 10:36 PM
Brad,
I, being at least as much of a rectum as yourself (IMG:style_emoticons/default/ohmy.gif) , would never consider relying on the website of companies that make this type of general product, hell there are plenty of people whose SPECIALTY is porsche and they tell you STUPID things, like the MFI fuel filter is the right one for the 914-6, and that the 914-6 rear brake pads are the same as the 914-4 rear pads. Also, note that they do not mention marelli in the text, I think you will get a unit that fits in a Bosch. I hope you're right, but I'm skeptical here. Mark S. '70 914-6 |
Brad Roberts |
Feb 23 2003, 11:16 PM
I agree Marc.
Elsewhere in the website... they specifically use the term Marelli. The part numbers they give are very generic and fit almost everything made with a dizzy. I used this exact Crane setup in a Marrelli on a 9146 conversion car that I built 2-3 years ago. It had a very early 2.0 engine in it. I even have the box around here somewhere. B |
2teeners |
Feb 23 2003, 11:55 PM
actually, I had studied that page earlier and not knowing if i had a permatune cd, came away thinking it wouldn't work. the line beneath says specifically "6 cyl. except marelli". But great, if it will work i'll get it.
If this stuffs available, why does everyone ditch the marelli for a bosch? |
Brad Roberts |
Feb 24 2003, 12:10 AM
This is where Crane "thinks" they all came with Permatunes. They Permatunes are EXACT cheaper replacements for the Bosch CD box. The actually do nothing different from the Bosch CD box.
Correct. The line below it... has a different part number. People have a tendency to follow like sheep when it comes to car building. They go to Bosch because... "my friend did it" They dont look around for other alternatives before ditching something they have that may work. I agree that the Crane setup is not the best looking stuff in the world... but Crane has been around a lot longer than some other companies... so I have to think they have some kind of quality control. The other thing I liked about Crane... you can buy spare parts seperately and not have to buy complete kits to "get what you need". This is the 4cyl setup: |
Brad Roberts |
Feb 24 2003, 12:19 AM
2teeners |
Feb 24 2003, 12:39 AM
I've the cranes since they were allison on a variety of cars, and never been unhappy. I don't mind the setup a bit, except for making sure the wires don't crimp with the vacuum advance. I never have to open the distributor anyway because they work so well, and IMHO remove the worry about worn dist. shafts.
I've been sold on em since the first time I put a timing light on the car and it hit exactly the same spot every fire. I loved it> |
Brad Roberts |
Feb 24 2003, 01:03 AM
I forgot all about Allison. I thought they (Crane) had bought out some other company.
I'll order one this week and do the install on a 2.0 Marrelli dizzy. B |
mskala |
Feb 24 2003, 10:11 AM
QUOTE(Brad Roberts @ Feb 24 2003, 01:19 AM) That's a 'meatier' link. Notice that the 6-cyl version only works with the 'bottom advance', and the 914-6 version of marelli is the 'tall cap' or top advance. But I'm sure with some messing things can always be made to fit. Like you were saying, these distributors are not hugely different in size than bosch. 2teeners: you don't have a vacuum advance, I hope you knew that. Mark S. '70 914-6 |
2teeners |
Feb 24 2003, 08:36 PM
yeah, I know i don't have vacuum advance. The phrase just slipped out of my flying fingers and I didn't catch it. :cursor: (IMG:style_emoticons/default/sad.gif)
Brad Roberts |
Feb 25 2003, 02:45 AM
The MSD billet dizzy I installed today had top advance and a very similar setup to the Crane. I dont recall much effort in getting it to work last time. I'll let you know.
B |
Dave_Darling |
Feb 25 2003, 03:15 PM
Psst! B! Suggestion--
Do the setup work, then have Mueller fab up a bracket that lets you bolt the thing in. It won't make you much, but it's a little bit, and it'll keep Mueller from breaking anything else on his car for a few hours.... (IMG:style_emoticons/default/wink.gif) --DD |
Brad Roberts |
Feb 25 2003, 11:35 PM
Best damn advice this week D. LOL
B |
Lo-Fi Version | Time is now: 12th June 2024 - 12:29 PM |
