Oil plug above sender plate, Oil Plug |
Stieve |
May 20 2006, 01:06 PM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
Ok guys, on the front of the engine, is a oil plug 32mm, above the drivers side motor mount, there is stud and another hole for a bolt, anyone know what goes there? Is this used for something? Is there a plate that bolts on there? I had oil leaking from there and pulled the plug out and it is open to the oil temp sender plate area from inside. Anyone????
So.Cal.914 |
May 20 2006, 02:05 PM
Pic's
Stieve |
May 20 2006, 02:58 PM
rhodyguy |
May 20 2006, 03:08 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
no picture. my minds eye sees the bolt on the side of the case that retains the little metal wheel that the thermostat wire runs on.
k |
Stieve |
May 20 2006, 03:10 PM
Stieve |
May 20 2006, 03:11 PM
type47 |
May 20 2006, 04:05 PM
stud/bolt and hole makes me think thermostat?
rhodyguy |
May 20 2006, 04:21 PM
is it shown in this picture? note the black spot, and i stubbed my toe.
k |
So.Cal.914 |
May 20 2006, 05:07 PM
I must be dense today, I thought you were talking about the area above the
engine mount on the front of the case. But your pic shows the bottem of the case and the rubber mount is in the way for me to see much of anything above the engine mount. Try me again. (IMG:style_emoticons/default/smoke.gif) |
rhodyguy |
May 20 2006, 05:14 PM
that's a picture i took. i have no idea where the bolt, stud, hole are actually located. that's what i'm trying to sort out.
k |
Lo-Fi Version | Time is now: 28th May 2024 - 07:55 PM |
