CV joint axel replacement |
echocanyons |
May 21 2006, 03:02 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I destroyed my inner CV joint while installing my engine. I figure now is a good time to replace all of the CV joints.
Can I remove the outer CV from the stub axel with the trailing arm on the car? I really want to avoid replacing the rear wheel bearings again. BTW these are the 69-73 911 types not the stock ones. |
davep |
May 21 2006, 03:42 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You should not have to disturb the bearing or the alignment. Remove the inner CV from the tranny, remove the nut on the end of the stub axle, and pull the whole drive shaft out. You may have to remove heat exchangers or loosten the shocks to get enough room to get the shaft out of there. If you can remove the inner CV from the shaft, that may also help.
echocanyons |
May 21 2006, 04:05 PM
Thanks Dave (IMG:style_emoticons/default/beerchug.gif)
I wanted to remove the outer cv joint from the stub axel. I removed the bolts but it seems like the pins are sticking. I guess it's just a matter of brute force. |
So.Cal.914 |
May 21 2006, 04:36 PM
Use force , but don't be a brute about it. Some gental persuasion should do it.
(IMG:style_emoticons/default/smoke.gif) |
Cap'n Krusty |
May 21 2006, 04:37 PM
Hope you have some CV joints. They're NLA. The Cap'n
Aaron Cox |
May 21 2006, 04:54 PM
Thanks Dave (IMG:style_emoticons/default/beerchug.gif) I wanted to remove the outer cv joint from the stub axel. I removed the bolts but it seems like the pins are sticking. I guess it's just a matter of brute force. thats your outer CV... what dave said. pull the stubaxle nut, pull the inner cv off the trans... and pull or lightlt tap the whole assembly out of the hub..... |
echocanyons |
May 21 2006, 04:59 PM
Yep its the outer I need to remove, I destroyed the inner CV.
I plan on using the whole axel replacement, I hope these are still available. Do I have to pull the axel nut? Can I not separate the stub axel from the CV joint? |
Aaron Cox |
May 21 2006, 05:02 PM
Yep its the outer I need to remove, I destroyed the inner CV. I plan on using the whole axel replacement, I hope these are still available. Do I have to pull the axel nut? Can I not separate the stub axel from the CV joint? its just easier to pull the axle nut... and slide the whole stub axle out of the hub... you cant get the cv off the stub without some "prying" usually.... pull the stub, and then seperate it on the bench.... good luck finding replacement axles..... |
echocanyons |
May 21 2006, 05:06 PM
That makes sense Araron, probably easie to put back together that way.
Are the 69-73 911 axle/cv assemblies in short supply too? |
Dr. Roger |
May 21 2006, 05:15 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
unfortunately, sometimes the bearing comes out with the stub and then you've got another issue to handle.
everyone's right about about prying to get that CV off.... i tried it your way and couldn't . I think it was Mike Mueller who showed me how to do this. just be as gentle as possible when driving that stub out. remove the large castle nut and turn it around and spin it on until the nut threads are almost all hidden (keeps from mushrooming the stub end) . I used a 2X4 with a sledge hammer on the nut/stub. one stub came right out. the other came out with the inner bearing and seal..... =-( I was going to replace them anyways... LOL good luck! Roger |
Dr. Roger |
May 21 2006, 05:18 PM
oh, and patrick motorsports makes the adaptors to convert your stocker to the 110mm turbo carrera CV's and 5 blt. it's a little over the top for a stock 914. =-)
i've got the details if you need 'em. |
Aaron Cox |
unfortunately, sometimes the bearing comes out with the stub and then you've got another issue to handle. remove the large castle nut and turn it around and spin it on until the nut threads are almost all hidden (keeps from mushrooming the stub end) . I used a 2X4 with a sledge hammer on the nut/stub. one stub came right out. the other came out with the inner bearing and seal..... =-( I was going to replace them anyways... LOL good luck! Roger the STUB is SPLINED onto the hub. wont even touch the bearing (IMG:style_emoticons/default/smoke.gif) you are interchanging hub and stub i think..... |
michelko |
May 22 2006, 03:24 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
unfortunately, sometimes the bearing comes out with the stub and then you've got another issue to handle. remove the large castle nut and turn it around and spin it on until the nut threads are almost all hidden (keeps from mushrooming the stub end) . I used a 2X4 with a sledge hammer on the nut/stub. one stub came right out. the other came out with the inner bearing and seal..... =-( I was going to replace them anyways... LOL good luck! Roger the STUB is SPLINED onto the hub. wont even touch the bearing (IMG:style_emoticons/default/smoke.gif) you are interchanging hub and stub i think..... (IMG:style_emoticons/default/agree.gif) and donĀ“t forget to put the car on jack stands. The bearing will maybe destroyed with the load of the car nothing holding the inner races together!!! (IMG:style_emoticons/default/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:36 PM |
