part #s for engine tin grommets |
mightyohm |
May 23 2006, 01:32 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I am trying to order new grommets for my engine tin but I can't find them all in PET. Specifically I am missing part #s for all of the grommets for the rear tin, such as the one that the battery cable passes through. Does anyone have a list?
Mark Henry |
May 23 2006, 06:27 AM
Go to www.cip1.com they have all kinds of VW engine seals.
JeffBowlsby |
May 23 2006, 10:06 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
JK, Here are a few photos I have of those grommets. Looks like a couple of them have PN on them, but I will need to find them to tell you what they are...
Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
May 23 2006, 10:07 AM
1 mo'
Attached image(s) |
mightyohm |
May 23 2006, 10:39 AM
Thanks Jeff, I'm not even sure I know what all of those grommets are for! I would greatly appreciate the part #'s if they are VW and not manufacturer's numbers.
I intend to come up with a list, check around at a few vendors to find out what is available, and post what I find here. |
JeffBowlsby |
May 23 2006, 10:43 PM
Here is the skinny:
The top two grommets in photo 1 above are the same, PN 021.119.569A, the lower left D-shaped grommet is PN 021.127.591, both are VW PNs. The lower right grommet in photo 1 and the deep round grommet for the battery+ cable on the passenger side have no number on the part. I am certain there are standard grommets available that will do the trick. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:31 AM |
