roll bar seal, window won't close |
will |
May 25 2006, 12:59 AM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
after installing the side roll bar seal from AA, the window glass does not roll up properly. the glass hits the rubber seal and cannot roll up. Is it the seal or does the window glass needs adjustment? The window glass rolled up just fine with the original seal. Any help would be much appreciated.
thanks will (IMG:style_emoticons/default/biggrin.gif) |
Aaron Cox |
May 25 2006, 01:02 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
adjust the glass. procedure is described for early and late window mech in your haynes....
MoveQik |
May 25 2006, 01:05 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Agreed. Adjust the glass. I have the same rubber from AA. New rubber vs 30 year old rubber requires some adjustment. (IMG:style_emoticons/default/smile.gif)
will |
May 25 2006, 01:13 AM
thank you. I will do that first thing in the morning.
Lo-Fi Version | Time is now: 8th June 2024 - 01:14 PM |
