Ok This is a weird one, Turn Signal / Seat Belt Warning Light |
tdgray |
May 27 2006, 07:24 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
OK Maybe someone has run into this.
I was installing my tail lights yesterday. Had to figure out the wiring. As usual the Haynes manual was pratically worthless. Think I have it all figured out.. at least everything is working as it should on the outside. Here's the problem. When I turn my turn signals on the seat belt warning light flashes along with it, both directions. But, here's more wierdness, the turn indicator on the tach will work correctly if I turn the drivers side TS on. If I turn the pass side TS on the indicator in the tach flashes as if I have the hazard switch on (you know both arrows). Note: everthing is working outside the car just fine. Just not inside. Also... where is that F&#$(&ing seat belt buzzer so I can disconnect the damn thing. Really F'in annoying. EDIT - Oh and I just noticed that the hazard switch is not working. |
tdgray |
May 30 2006, 03:01 PM
(IMG:style_emoticons/default/icon_bump.gif) for the post holiday crowd.
Any ideas people... (IMG:style_emoticons/default/blink.gif) |
Dr. Roger |
May 30 2006, 03:31 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Rand |
May 30 2006, 03:41 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
where is that F&#$(&ing seat belt buzzer so I can disconnect the damn thing. Seatbelt relay annoyance device is under the passenger seat. You can rip it all out and just join the big yellow wire (starter circuit) and the brown-only grounds. In your general rounds, make sure all the contacts are clean at the fuse panel and taillight bulbs. |
tdgray |
May 31 2006, 06:12 AM
Thanks Doc... but I have a 73... donna have all that crap. (thank God). I will take a look at the fuse block this weekend. |
GaroldShaffer |
May 31 2006, 06:22 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have the same problem with the turn signal on the tach. driver side works as it should but when passenegr side is turn both flash on the tach. My problem is the front turn signal housing. The bulb doesn't fit tight in the socket and I have to bend the socket to get the bulb tight. Yes it is the correct bulb, just a feature of my car (IMG:style_emoticons/default/biggrin.gif)
Check and make sure the bulbs are tight in the socket. |
Lo-Fi Version | Time is now: 14th June 2024 - 02:32 AM |
