Wiring help |
Wiring help |
watsonrx13 |
May 28 2006, 04:17 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I have a wiring problem that I can't figure out. Currently all the lights are working correctly, blinkers, driving, back up, brake. But, when I turn the ignition on, the blinker lights in the dash are on and the left rear driving and side marker lights are on. I have unplugged the gray/black wire, which turns the driving and side marker lights off, but the dash blinkers stayed on. When I drive the car and use the blinkers after a few turn signals, the blinker lights in the dash finally go out. They will blink when the turn indicator is turned on....
I checked the wiring in the left rear and it appears to be wired up correctly, so where do I check next? Obviously the rear lights are getting constant power from somewhere, I just don't know where to check next... -- Rob |
Joe Ricard |
May 28 2006, 07:55 PM
Turn signal relay is sticking.
watsonrx13 |
May 28 2006, 08:48 PM
Joe Ricard |
May 29 2006, 09:48 AM
Bump for Rob,
Turn signal relay is exactly where the BOOK says it is. Sorry I couldn't resist that one. and no head light relays won't work. FLAPS have them. or you could pull yours and open it up and clean it. |
Lo-Fi Version | Time is now: 4th June 2024 - 07:00 PM |
