a puzzle and a prize, food for solutions |
nycchef |
May 29 2006, 11:02 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
73 1.7 will not go past 4000rpms in any gear. changed vacuum hosese, fuel lines, timing, dwell, dizzy,cht, fuel tank. solve this for me and all this and more are yours.
Attached image(s) |
Aaron Cox |
May 29 2006, 11:03 AM
could be the fact that..........
IT'S a 1 . 7 (IMG:style_emoticons/default/chairfall.gif) sorry. no help.... AA |
bondo |
May 29 2006, 11:04 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Maybe you have a /6 tach? (IMG:style_emoticons/default/smile.gif)
brp914 |
May 29 2006, 11:14 AM
Unregistered |
dang...gonna need some extra tall jack stands after all that.
does it idle ok? if so, measure intake vacuum. you should get atleast 14inch Hg. the idle air adj. screw should be nearly closed. measure fuel pressure - should be around 28psi good luck |
boxstr |
May 29 2006, 11:24 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Have you checked the rotor, could it be a rev limiter type to 4000rpm??
CCLIN400rpm |
Allan |
May 29 2006, 11:47 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
You didn't mention valves... (IMG:style_emoticons/default/chowtime.gif)
rmital |
May 29 2006, 11:51 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
...great, I'm at work, depressed and hunger...thanks chef!
nycchef |
May 29 2006, 12:11 PM
don,t think so engine flies up to red line in nuetral and car juswt has no power. but will look into it thanks. come to nyc and the bbq is yours. rich |
nycchef |
May 29 2006, 12:13 PM
thats the next step. was about to do that sat when a blew out a brake line playing mario andretti. if you are right i'll start cooking thanks rich |
Allan |
May 29 2006, 12:32 PM
I would also check Craig's tip about the rotor...
brp914 |
May 29 2006, 12:41 PM
Unregistered |
if your valves are so out of adjustment that it wont go past 4k, it wont idle well. if your valves are excessively loose, that engines gotta be making hellaciuos racket. and if excessively tight and driven that way for a while, your valve train is likely bbq'd along with those ribs.
is this a djet or carbs? |
nbscooters |
May 29 2006, 01:02 PM
Member Group: Members Posts: 165 Joined: 29-June 05 Member No.: 4,347 Region Association: None |
check the trigger points.
So.Cal.914 |
May 29 2006, 06:01 PM
Something else that could cause that is a warn cam and followers. How many miles on the bottom end?
(IMG:style_emoticons/default/smoke.gif) |
ptravnic |
May 29 2006, 07:30 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Rich -
Not sure if you have checked out Paul Anders D-Jet troubleshooting/info pages... http://members.rennlist.com/pbanders/ -pt |
jsteele22 |
May 30 2006, 09:51 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Q : What did you feed it ? I wouldn't do much more than idle after a plate like that ! Good luck. |
Dr. Roger |
May 30 2006, 10:04 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i hope, for your sake, it's a timing issue.
if it is a crapped out cam i know that sir andy had a good used 1.7 for sale for a respectable price. |
ejm |
May 30 2006, 11:04 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE engine flies up to red line in nuetral Does the throttle open all the way? |
John |
May 30 2006, 11:54 AM
Does it break up at 4000 RPM real badly?
Swap out the coil for a known good one and see if that might be it. |
ptravnic |
May 30 2006, 12:44 PM
I don't know much about what a bad coil acts like but they're pretty cheap - maybe $30 or so.
Leo Imperial |
May 30 2006, 11:32 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Update on the car....
Rusted brake line has been replaced. Master is leaking like a ... lets just say big puddle Gas pedal to be welded/repaired to avoid sticking - Wow no brakes and sticking throttle that was (IMG:style_emoticons/default/ohmy.gif) Fuel pump connection was not conected it was arcing at the pump. More on that tomorrow not sure it will fix the 4000 rpm thing It's gonna run nice real soon |
Lo-Fi Version | Time is now: 7th June 2024 - 04:54 AM |
