1976 914 Fuel Pump Gremlin :(, HELP!!! |
kskwpb |
May 30 2006, 11:36 AM
Newbie Group: Members Posts: 20 Joined: 30-May 06 From: West Palm Beach Member No.: 6,098 |
Hey ALL. Kevin in West Palm. I bought a 1976 914 2.0 FIw/78,000 mi REAL nice car...But...has MAJOR fuel pump gremlins. Somtime the pump will come on,more often than not it won't. I can't even locate the fuel pump on the car? Sad huh? Also the owner before me put this reflector thing across where the rear trunk lock was and I can't figure out how to open trunk?Any & all help PLEASE (IMG:style_emoticons/default/smile.gif) Thank You & Best Regards, Kevin King
Mueller |
May 30 2006, 11:39 AM
fuel pump is in the front under the gas tank....
a Haynes manual would show you (IMG:style_emoticons/default/smile.gif) |
kskwpb |
May 30 2006, 01:05 PM
fuel pump is in the front under the gas tank.... a Haynes manual would show you (IMG:style_emoticons/default/smile.gif) Thank you!!! |
Dr Evil |
May 31 2006, 01:43 PM
You may wish to check the fuel pump fuse in the engine compartment, left side, on the circuit board. Clean the contacts on it and the board asn see what happens. Also, the fuel pump relay is on the same board. The Haynes manual will tell you wich one. You can swap the head light relats from the front with the fuel pump relay to trouble shoot. Your fuel pump should have an access panel in the front trunk, onthe lower drivers side of the wall in front of the gas tank. |
kskwpb |
May 31 2006, 02:30 PM
(IMG:style_emoticons/default/welcome.png) You may wish to check the fuel pump fuse in the engine compartment, left side, on the circuit board. Clean the contacts on it and the board asn see what happens. Also, the fuel pump relay is on the same board. The Haynes manual will tell you wich one. You can swap the head light relats from the front with the fuel pump relay to trouble shoot. Your fuel pump should have an access panel in the front trunk, onthe lower drivers side of the wall in front of the gas tank. You Guys are THE BEST (IMG:style_emoticons/default/smile.gif) I was thinking of selling car...but...The guys on this site are having WAY TOO MUCH FUN!!! Cheers, Kevin. |
eeyore |
May 31 2006, 02:49 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Pull out all the junk you have the front trunk. The fuel pump should be behind a 3" x 6" (80mm x 160mm for Andy) black panel on the rear trunk wall.
Bleyseng |
May 31 2006, 03:40 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I have the rear reflector too and there should be a little button (mine is on the fuse panel and red) that opens the trunk. Sometimes the inline fuse blows so it doesn't open and the key must be on for the relay to work to pop the rear trunk.
AZ914 |
May 31 2006, 03:50 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
The previous owner of my car put an electronic opener on my trunk as well. He rigged a little rocker switch that is mounted under the lower dash pad. (out of site, below the cig lighter). Look down there for something.
Welcome to the madness! |
ws91420 |
May 31 2006, 05:01 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Check the ground on the front pump for intermitttent problems. The trunk release for mine was a button in the glove box. Also if the reflector has a small hole drilled in it about mid way you can put a dental pick in there and pop the lock. Also check and see if he did a cable operated release from the engine comparment area. (IMG:style_emoticons/default/welcome.png)
Lo-Fi Version | Time is now: 1st June 2024 - 06:55 AM |
