Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
As alot of you know I've had a TON of problems with the six conversion I bought last year.
The biggest was a major head leak that lead to a complete tear down. The big IF was that everywhere I turn, I hear the same thing over and over: It is impossible to get a 2.7 mag case engine to be leak free.... I'm not 100 percent sure but I think I have one. After two (2) tear downs, I have put at least 1 a/x and 1000 miles on it since I got it back with ZERO motor leaks. Should I give it some more miles or can I claim Victory over the mag case leak delimma? |
fuch toy |
Unregistered ![]() |
If done right...they won't leak....it's NOT a 4 banger....
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
unfortunately it is only a matter of time (IMG:style_emoticons/default/sad.gif)
My 2.7RS motor was built on a 7R mag case and was resealed 2 times. Got it down to just on small drip but it always started out good until you get quite a few heat cycles then it starts somewhere. If it stays dry yours would be the first 7R case I have ever seen or heard of that stayed dry. My case was shuffle pinned and time certed and still had one small drip...no matter how much RTV was used to put the case back together. good luck |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
I have always heard and believed that all 911 engines leak, it's only a matter of when and how much.
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
If done right...they won't leak....it's NOT a 4 banger.... that sounds like a (IMG:style_emoticons/default/poke.gif) |
Cap'n Krusty |
unfortunately it is only a matter of time (IMG:style_emoticons/default/sad.gif) My 2.7RS motor was built on a 7R mag case and was resealed 2 times. Got it down to just on small drip but it always started out good until you get quite a few heat cycles then it starts somewhere. If it stays dry yours would be the first 7R case I have ever seen or heard of that stayed dry. My case was shuffle pinned and time certed and still had one small drip...no matter how much RTV was used to put the case back together. good luck If you used conventional RTV, you'll NEVER keep it leak free. The Cap'n |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
RTV, at least the normal stuff does NOT like high temps at all....
b |
turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
And I read this after getting under my car and noticing a few leaks. One is the the valve cover and the other looks like the seal at the axle. Well not leaking bad (IMG:style_emoticons/default/drunk.gif)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE A leak free 2.7, Is it possible? No. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
my bone stock original 70,000 mile 3.6 leaks oil (IMG:style_emoticons/default/headbang.gif)
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Bullshit! My engine doesn't leak any more oil since the last big leak I had.
Thats because it is out of oil and I have not refilled it (IMG:style_emoticons/default/biggrin.gif) Sorry, couldn't resist. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I'm sure it's possible.....but not at my house (IMG:style_emoticons/default/sad.gif)
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
A brand-new non-used 2.7 turnkey still in original crating from Porsche with 0 miles will not leak.
At least, until you run it. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
they dont leak, if they dont have oil LOL
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
leaking engine means it running. Damn I get a can of degrease and go to the car wash - its a lot cheaper than rebuilding an engine!
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
I've heard it said that, with God, all things are possible.
Some are just more likely than others. Leak-free 2.7? I think that would fall in the latter category... |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
They say "Harley's don't leak they mark their spot." I believe Porsche's have the same attitude, mine will get even if I don't treat it right.
(IMG:style_emoticons/default/smoke.gif) |
BajaXJ92 |
Extended Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region ![]() |
As alot of you know I've had a TON of problems with the six conversion I bought last year. The biggest was a major head leak that lead to a complete tear down. The big IF was that everywhere I turn, I hear the same thing over and over: It is impossible to get a 2.7 mag case engine to be leak free.... I'm not 100 percent sure but I think I have one. After two (2) tear downs, I have put at least 1 a/x and 1000 miles on it since I got it back with ZERO motor leaks. Should I give it some more miles or can I claim Victory over the mag case leak delimma? Now why would you want to get rid of the auto-undercarriage oiling system? Its rust preventative! (IMG:style_emoticons/default/bootyshake.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Lo-Fi Version | Time is now: 14th June 2024 - 03:55 PM |
