Stupid ? 101 - How to remove tray at rear of console, I know I should know |
db9146 |
Jun 2 2006, 10:22 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Okay, I have looked it over carefully, but I can't find any screws in the rear corners holding it down. There was one in the front that was also holding down the console. (IMG:style_emoticons/default/blink.gif)
The only ones I can still see are those holding the tray together at the back. I have tried sliding it forward now that the console is out of the way but that didn't work either. What next? (IMG:style_emoticons/default/headbang.gif) |
tdgray |
Jun 2 2006, 11:42 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Are you speaking of the Center Console or the Third Seat Tray.
Please clarify and we can help. |
rjames |
Jun 2 2006, 12:07 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Center guage console? Is there a screw holding it to the underside of the dash?
jtf914 |
Jun 2 2006, 01:35 PM
Member Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
If you are asking about the 3 gauge, center console..... I think you just remove the flat panel that covers the shifter, and heater lever, and the mounting screws are under there.
TROJANMAN |
Jun 2 2006, 01:39 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
he's talking about the third seat tray
"....The only ones I can still see are those holding the tray together at the back. I have tried sliding it forward now that the console is out of the way but that didn't work either...." |
Rand |
Jun 2 2006, 01:43 PM
On mine, the tray between the seats is screwed through the bottom into the center tunnel. Four screws at the corners I believe. Heads visible in bottom of tray. With all the screws out it just lifts out.
The gauge panel is not screwed in... snaps in with clips. Just pull it towards you but be careful to not pull the clips out... kinda like a door panel. |
db9146 |
Jun 3 2006, 06:28 AM
This is the tray between the seats at the back of the console (guages and console are already out). I looked for the screws inside the tray in the bottom of each corner but I didn't see them. That's why I was thinking that there might be some clips under the tray that it slides into to hold it down. I've looked three times, I guess a fourth won't hurt.
elocke |
Jun 3 2006, 06:47 AM
Member Group: Members Posts: 178 Joined: 9-February 03 From: Georgetown, MA Member No.: 272 |
Mine also has 4 screws in the corners of the tray, AND 2 screws in the front.
Ed Attached image(s) |
JPB |
Jun 3 2006, 07:15 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
:sawzall:Agnaaaaaa, got da scwoodriva boss.
Lo-Fi Version | Time is now: 7th June 2024 - 04:56 AM |
