Nailed: See my other important thread here, here's my other thread |
redshift |
Jun 3 2006, 09:59 PM
http://www.914world.com/bbs2/index.php?showtopic=53106
Just in case you missed it, I nailed this one, so it will stay at the top of the messages list until someone rents a truck, and comes to pick up my car. I expect to have one of you lucky winners restore my car, for free. Right now though, just make it run, and I won't have to get really mad. Thanks, (IMG:style_emoticons/default/smash.gif) stay! (IMG:style_emoticons/default/smash.gif) I NAILED YOU! STOP IT! (IMG:style_emoticons/default/sheeplove.gif) |
redshift |
Jun 3 2006, 10:22 PM
Nailed!
redshift |
Jun 3 2006, 10:24 PM
It seems to be staying at the top now, so I will go away for a few minutes, and you guys figure it out.
I'll be back. M |
redshift |
Jun 3 2006, 10:26 PM
redshift |
Jun 3 2006, 10:34 PM
Look, we all know this isn't really nailed, I am just bumping it up to the top every thirty seconds..
I just need attention. Hold me.. M |
iamchappy |
Jun 3 2006, 10:46 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Miles your not the only one with car that just sits there, some of us have gotten used to having a 914 for a garage or lawn ornament. 914's are to be seen not heard.
The non running 914 club membership is the majority not the minority. Join the non running 914 club. Member list starts add here: 1-Miles 2-Chappy 3-Qarl 4-Bork 5-Rick Alien |
redshift |
Jun 3 2006, 10:48 PM
(IMG:style_emoticons/default/huh.gif) FINALLY!
No! I can't! I have to make it move first, then I can park it! It's only a mile away... I walked here! DAMNED CAR! I am going to hotwire the pump... if I can figure out how to do that... -blows up self- I hope the pump works! M (IMG:style_emoticons/default/smile.gif) |
SirAndy |
Jun 3 2006, 10:53 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am going to hotwire the pump... if I can figure out how to do that... just leave the FI connector on the relay board and add a ground wire on that pin.. that'll make your pump run as soon as you turn on the key ... (IMG:style_emoticons/default/smile.gif) Andy |
iamchappy |
Jun 3 2006, 10:56 PM
Pull fuel pump relay out and jump terminals with a short wire until the pump starts, drive to a nice lawn ornament spot in the yard turn off car and disconnect jumper wire, go to bed...... Admire your ornament in the morning...
GWN7 |
Jun 3 2006, 10:59 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Push it home...there are no hills there and you have been putting on weight lately.....Oh I have a brick of 3 yr old white chedar...the kind that makes the hair stand up on your tounge
redshift |
Jun 3 2006, 11:06 PM
The relay is good, what if my board went dumb?
The (black?) wire broke off the coil. Is that the tach? (I think) Someone tried to help me in mostly dark. I hate you Bruce, I should have you deported. Thanks guys... (except for Bruce, of course).. M |
ThinAir |
Jun 4 2006, 12:43 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I just had a similar experience. Fuel pump wouldn't do a thing. I tried a known good relay and it didn't change anything. I had power on both sides of the fuse on the relay board, but no power on the positive lead at the pump. Today I figured out that the relay board went bad on me. Fortunately I've got another that I could put in place to make sure.
If the relay board is bad, then I doubt that a jumper in place of the relay will do you any good. A couple of years ago I had a similar problem and I just disconnected the positive lead on the pump and ran a wire directly to the battery to get me home. When I got there I shut off the engine, then disconnected the wire. |
redshift |
Jun 4 2006, 12:53 AM
I just remembered that when I installed new relays, the pump wouldn't work for some reason, but it would work with a test relay I shimmed.. until I seated the new one a hundred times.
I think I know what it is... thanks guys.. I can't sleep... I hope my car is ok.. Come home, sweetie! M |
VegasRacer |
Jun 4 2006, 05:40 AM
ELVIRA Group: Benefactors Posts: 8,523 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Maybe you're outta gas?
JPB |
Jun 4 2006, 06:15 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Operator error. Could have been worse, ya could have had a hot Swedish chic with ya and looked like a you know what .
Gint |
Jun 4 2006, 08:05 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Eric_Shea |
Jun 4 2006, 09:48 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
nailed...
I'm betting on the bad gas thing. Especially with that brick of aged cheddar. In fact, I'm certain Miles has bad gas. (IMG:style_emoticons/default/wink.gif) |
redshift |
Jun 4 2006, 09:50 AM
I can't have all the bad gas, what would you BAGS be full of...
oops.. that's right... sheep dip! (IMG:style_emoticons/default/sheeplove.gif) |
GWN7 |
Jun 4 2006, 11:06 AM
As I'm being deported anyways.......guess what I had for breckfast? A cake donut with cinnamon and sugar coating. Then I got in my Running 914 and drove to work. hahahahaha....
Aaron Cox |
thats cold B
Lo-Fi Version | Time is now: 2nd June 2024 - 12:52 AM |
