Weber IDF40 Question, Main Top Gasket |
Spoke |
Jun 4 2006, 10:41 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Simple question which I think I know the answer but just want to check. Don't have a repair manual.
Question: The gasket between the body and the top does not get gasket sealer? Just tighten down dry. Correct? Thanks in advance, Spoke Attached image(s) |
Rouser |
Jun 4 2006, 10:52 AM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Question: The gasket between the body and the top does not get gasket sealer? Just tighten down dry. Correct? Yep, no sealer; none required. Also, when setting the float level(s) (opened & closed), set them with the gasket in place, taking into account its thickness. |
Gint |
Jun 4 2006, 10:54 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That's correct. Gasket and *NO* sealer.
Aaron Cox |
Jun 4 2006, 10:55 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
no sealer anywhere on the carbs.....
set your float while youre there... |
Spoke |
Jun 4 2006, 11:00 AM
Guys, Thanks!!! You confirmed my understanding. Already set the float with gasket in place. 914club rocks. Got some cold ones for ya (IMG:style_emoticons/default/beerchug.gif) Oh, you guys aren't nearby. Ok, then I down a couple for ya (IMG:style_emoticons/default/beer3.gif) Its after noon here.
Spoke |
Lo-Fi Version | Time is now: 7th June 2024 - 01:18 AM |
