OIL TEMPERATURE GAUGES |
Hartmann |
Jun 4 2006, 02:54 PM
Newbie Group: Members Posts: 48 Joined: 11-August 03 From: Plattsburgh, NY (60 miles south of Montreal) Member No.: 1,014 |
I just installed a combo gauge, the one that has the oil temperature gauge built in, into my 914. Does anyone know at what temperature the oil is when the needle hits the RED mark?
Also, I still have a VDO oil temp gauge with degree marks in my console. They both give a reading, however does anyone know if the oil temp sensor is the same for the stock gauge and the VDO degree gauge? |
LvSteveH |
Jun 4 2006, 09:58 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Depending on the gauge you have, you should be able to look at the lines on the gauge, then follow the line to the left and look at an angle where the line goes into the gauge. It should have the temp in celsius in VERY small writing. I think the first line is 190f (8 o'clock), the 2nd is 240f (9 o'clock), and the red is around 300f. That's from memory. Check the bird board to verify.
Just a note, you should really confirm the temp of the engine with an infra/laser temp on the oil filter or the sump to ensure the gauge and sender are on the same sheet of music. |
Hartmann |
Jun 6 2006, 04:27 PM
Thanks Steve - I will take a good close look at the gauge. RH
Depending on the gauge you have, you should be able to look at the lines on the gauge, then follow the line to the left and look at an angle where the line goes into the gauge. It should have the temp in celsius in VERY small writing. I think the first line is 190f (8 o'clock), the 2nd is 240f (9 o'clock), and the red is around 300f. That's from memory. Check the bird board to verify. Just a note, you should really confirm the temp of the engine with an infra/laser temp on the oil filter or the sump to ensure the gauge and sender are on the same sheet of music. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:52 PM |
