Spring is Sprung, The Grass is Riz,, And the rear end of my car is as crooked as a.......... |
balljoint |
Jun 5 2006, 11:18 AM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
914 with a ride height 1.5" shorter on the passenger side at the wheel well.
Does that rhyme? New springs and the problem is solved right? 100-140 lb? Are there a number of different manufacturers that make springs that happen to be the correct size and I should just poke around or is there a preferred manufacturer (or un-preferred). Also, and in addition, I happen to have a brand-spankin' new set of Koni Yellows that came with the '71, never installed. Is there any difference from the '71 to the '74 as far as the rear shocks go? Gracias in advance Chicos and Chicas, |
So.Cal.914 |
Jun 5 2006, 11:33 AM
This could also be your wake up call. Check your rear trailing arm pivot points,
acid from the battery can eat the long and suspention console and it usually begins with a sag. There are different companys that make springs for them, progressive and not. And many different ratings it just depends on what you are going to do with it. I run canyons and use 140 lb. springs some guys run on the track and use 250 +. As far as who to get them from there are many suppliers, I am sure that pelicanparts.com could help you. Those koni's will fit on the back. |
balljoint |
Jun 5 2006, 11:53 AM
No rust on this body. I went the way of buying the best car I could afford for my second teener. S M R T (IMG:style_emoticons/default/stan.gif)
r_towle |
Jun 5 2006, 12:39 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
did you have the rear up in the air this past winter???
If so, possibly one of the springs is not sitting in the perch correctly... jack it up and see if they are sitting in the perch the right way both top and bottom. BTDT. As far as springs go, you need the same outer diameter, so PP has those. the shocks should be the same. Rich |
lotus_65 |
Jun 5 2006, 04:42 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
mine's similarly afflicted, but i ride high on the pass. side. mine's ok for rust too, and i thought maybe it had gone off road and torqued the tub a little before i bought it.
Tom Perso |
Jun 5 2006, 08:25 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Have you driven the car since making the changes? I wonder if the car sitting up in the air made one of the bushings take a "set" and now it's binding up.
I'd take it for a drive and see if it settles out. Beyond that, I can't offer any more help. Tom |
Aaron Cox |
Jun 5 2006, 08:28 PM
is the front sagging??? broken torsion bar can do that....
if its just the rear.... i have no idea... |
Toast |
Jun 5 2006, 10:35 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 1st June 2024 - 08:45 AM |
