TPS replacement |
TPS replacement |
sk8kat1 |
Jun 9 2006, 08:01 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
are there any things to watch out for on this..... it seems to be a un plug.. unscrew the mounting points and replace teh same ... is this right .. the haynes manual is vauge on the importance of the postioning of the part ..
any info? |
rmital |
Jun 9 2006, 08:09 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
toon1 |
Jun 9 2006, 08:13 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
there is a resistance measurement that needs to be taken. If the TPS does not reurn to a certain posistion it will continue to richen the fuel. It basically acts as a accell. pump.
Pelican parts has an artical on how to replace it. It's easy. |
sk8kat1 |
Jun 9 2006, 08:18 AM
there is a resistance measurement that needs to be taken. If the TPS does not reurn to a certain posistion it will continue to richen the fuel. It basically acts as a accell. pump. Pelican parts has an artical on how to replace it. It's easy. that explains the crappy gas milage ... but the article I found was calibrating it ... is it ok to just get it pretty close in comparison to the old one if you don't have an ohm meter ? |
srb7f |
Jun 9 2006, 08:39 AM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
Not really. You need to be certain that you have conductivity between the correct terminals while the throttle is in the closed (idle) position.
I bought a cheapo ohm meter for maybe $20 at radio shack and it's worked great for the past 6 years. One of those things you'll find a use for after you have it. Even a test bulb with a battery would work to rig up a test circuit, as the only readings you need to know are conductance vs. open circuit which would be bulb illuminated, or bulb out. |
Howard |
Jun 9 2006, 08:52 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
I'm sure the experts will rip me here, but with the key on, twist TPS slowly clockwise until you hear the contacts click. Turn it one small skosh more. Seems to work every time.
sk8kat1 |
Jun 9 2006, 09:06 AM
it was requested to post the PP link ....PP TPS cal link
sk8kat1 |
Jun 9 2006, 09:14 AM
so is it worth see if the TPS just needs to be adj ..or should I just replace it with the spare I have?
Lo-Fi Version | Time is now: 9th June 2024 - 08:04 PM |
